CV axle replacement - does it just pull out? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 03-08-2011, 11:36 PM
SparkyJJO SparkyJJO is offline
2002 Chevy TrailBlazer LS
My trailblazer developed a vibration in the front end recently, along with a swoosh-swoosh sound most noticeable around left turns. Started analyzing underneath and the large clamp on the inner CV boot is completely gone and there is grease EVERYWHERE lol. Not sure where the clamp went, it was there not long ago when I checked things over But I think the joint is pretty well shot already, it's original with 130k on it anyway, so I'm just ordering a cardone from Rockauto. Strange how the brand new one is cheaper than the rebuilt one
Anyway, I've been searching and reading on how to do the replacement. My Haynes manual goes as far as removing the entire shock assembly and everything, but from what I understand from reading on here that isn't necessary. But everything just says to "remove the half shaft" after freeing it from the hub - am I missing something? Does it just simply pull straight out of the front differential?
Old 03-09-2011, 07:51 AM
jbernatz jbernatz is offline
2004 Chevy TrailBlazer LS
Black 4.2L I6 4X4
I know, "pulls straight out" makes it sound easy, and infact it is technically that easy.
However the axle is usually locked in there fairly well so you will need either a slide hammer with the correct attachment to pull the tripod section out of the diff, or you can pull the oil pan skid plate and use a hammer and drift to hit the back side of the tripod to knock it loose and then pull it out.
Also, I found it's worth engaging 4wd when you're putting the new axle in, seems like it made it easier to get all the splines lined up in there.
Old 03-09-2011, 08:24 AM
Jolly01's Avatar
Jolly01 Jolly01 is offline
2003 Chevy TrailBlazer LS
"Also, I found it's worth engaging 4wd when you're putting the new axle in, seems like it made it easier to get all the splines lined up in there."
Good tip
Old 03-09-2011, 10:03 AM
hatchet669's Avatar
hatchet669 hatchet669 is offline
TrailVoy Guru
2003 Chevy TrailBlazer LT
if you can get a little bit of room under your truck... when i did mine (which was on a lift) but if you have a smaller crow bar, there is a hole in the frame directly below the attachment point for the half shafts... slide the crow bar up there and 2 yanks they popped right out...
sorry i dont have pics. but that was the easiest.
Old 03-09-2011, 12:29 PM
OK. I always get concerned when directions say "just pull" as it is almost never easy like that for me
I'll be doing this job on jackstands in the driveway, hopefully I'll have room enough to work.
Old 03-09-2011, 05:50 PM
Fishsticks Fishsticks is offline
2002 Locked Up Chevy TrailBlazer LTZ - Black w/
Herculiner and Rock Rash 4.2L I6 4X4
I use a pickle fork with about 1 in in between the tines and a 2 lb sledge. They always come out on the second or 3rd whack for me.
Old 12-28-2011, 01:44 PM
unclemoney unclemoney is offline
2003 GMC Envoy SLT
Black 4.2L I6 4X4
Old thread I know, but I was just wondering how things went! My new cv half shafts should be here today so I guess I'll find out soon enough! Lol
Tags
cv axle, vibration
