How to change rear wheel bearing in 05 Trailblazer - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > OEM Issues
OEM Issues OEM Repairs & Problems
Old 03-15-2011, 04:44 PM
kellygray67 kellygray67 is offline
2005 Chevy TrailBlazer LS EXT
Summit White 4.2L I6 4X4
I have already removed the tire caliper and rotor. Cannot figure out how to get to the bearing. Any ideas?
Old 03-15-2011, 05:08 PM
Cuda_Jim's Avatar
Cuda_Jim Cuda_Jim is offline
2005 Chevy TrailBlazer LT EXT
Graystone Metallic 5.3L V8 4X4
The rear axle bearings are not like the front, unitized, types. It's #23 in the picture below.
Short version:
You need to remove the diff cover (18), drain the fluid.
Remove the cross pin bolt (13) Pull the spider gear cross pin (14), push the axle(s) in and remove a "U" clip (36).
Pull the axle out of the housing.
Replace the seal too (24)
Horse power = How fast you hit a wall
Torque = How far you take the wall with you
Old 03-16-2011, 01:31 PM
Husband is working on it now. Thank you SOOO much!
Old 03-16-2011, 05:07 PM
Cuda_Jim's Avatar
You are welcome, hope it works out for you.
Oh, and one more thing, he will need a slide hammer to get the old bearings out of the axle. They can be rented at most auto part stores for just a deposit.
Old 03-20-2011, 12:59 PM
Turns out the bearings in both wheels were fine. Our next step is to take it to the shop lol. Any ideas what would make the same sound? I guess maybe a pinion bearing sounds alot like a bad wheel bearing from what I've been told. Would really like to do the work here @ home and save a couple bucks but from what I understand about changing the pinion bearing, looks like the shop is our only option.
Old 08-21-2012, 05:31 PM
NSTRAILBLZ NSTRAILBLZ is offline
2006 Chevy TrailBlazer LS
GOLD 4.2L I6 AWD
rear wheel bearings
@ cuda_jim hey how are you! i saw the post you left another member concerning this topic and i noticed that you posted pics of the procedure and i wanted to know if you were able to re-post those pics because im about to do the same job! TY!
Old 08-29-2012, 07:02 PM
crazytrailblaze's Avatar
crazytrailblaze crazytrailblaze is offline
2002 Chevy TrailBlazer LT
Black 4.2L I6 4X4
Hello , I have 02 tb lt 168k my rear wheel bearing will be coming off soon it's making a howling noise , I just replaced the front ones this morning, my question is how long would a job like this take a shop , shop is charging by the hour don't need to get hosed
Sent from my iPhone using Autoguide
