Removal of the EVAP Canister - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-09 SS Engine and Drivetrain > Engine Tunes/Mods
Engine Tunes/Mods Engine tuning and/or modifications
Old 05-12-2006, 11:23 PM
ScarabEpic22 ScarabEpic22 is offline
Northwest Chapter
not here not here not here
not here Other AWD
Okay, so I need to remove the EVAP canister and cant figure out for the life of me why I cant get it out.
My Haynes manual is worthless as all it says is remove the connections which I have done and then it says remove the bolt. Where in the heck is this bolt???
Thanks!
EDIT:
Nevermind, I got it out.
Old 05-13-2006, 03:48 PM
Northwest Chapter
not here Other AWD
Wow, it was late last night I guess, posting in the SS forums instead of the regular one.
Old 11-09-2009, 01:21 PM
super2 super2 is offline
2002 GMC Envoy SLT XL
HOW|??? I have the same prob. driving me fn crazy
Old 11-20-2009, 10:06 AM
ok, figured it out.... the manual calls it an EVAP canister, i finally google "charcoal canister" and found that the 02 TB is connected with a clip...no bolts...no straps...you have to work the "right side" (closest to the front)...you will see two clips and a slot for a screwdriver...place a screwdriver into the slot and work the clip off...the rear clip slides right off.
i had to remove the canister to swap out my transmission...(didnt work out to well for me)...will be asking what i did wrong in an upcoming post.
Old 03-06-2011, 04:11 PM
moparmerv moparmerv is offline
2004 GMC Envoy SLT
I too ran into this problem and the undo the bolt description in the Haynes manual. Thanks to your advice I got the can off without breaking it (I was getting close to just busting it off.
Thanks for saving my bacon.
-Chris
Old 11-08-2011, 10:28 PM
NatesGr8 NatesGr8 is offline
2004 Chevy TrailBlazer LT
Summit White 4.2L I6 4X4
[removed]
Old 08-13-2014, 06:09 AM
AlianaPop AlianaPop is offline
2004 Buick Envoy SLE
Graphite Metallic 5.3L V8 4X4
A great*exchange of information.
Old 02-06-2016, 08:57 PM
indy45 indy45 is offline
2002 Chevy TrailBlazer SS (LS)
Fire Red 4.2L I6 4X4
Removal of vapor canister in 02 Trailblazer
Thanks for your thread. I too have to remove the canister in order to remove one of the bolts in the cross member. I intend to reverse the bolt when I put it back together so removal of the canister won't be necessary if the cross member ever has to be removed again. I was prying on the canister, even used a screwdriver in the slots you mentioned. Evidently I didn't pry hard enough. Back to the task at hand with more confidence now
Old 03-07-2016, 05:52 PM
Turn2Smith Turn2Smith is offline
2003 GMC Envoy SLE
Sandstone Metallic 4.2L I6 4X4
Need to remove the Evap Canister, too
Hey here. I'm glad to hear you were successful. I'm not as lucky. So just to make sure, I need to be working on the clips closest to the cross member and not the clip near the gas tank.
I'll let you know how it goes.[IMG][/IMG]
Similar Threads
Thermostat repair- how to- pics included rbarrios The 02-09 "How-To" and DIY Section 349 10-10-2016 10:28 PM
Fan clutch 101 GMT 360 OEM Issues 366 12-01-2015 11:26 AM
WI Dealer giving me the BS on OCI? Knightslugger General 48 10-10-2009 12:12 PM
GM's Future including Trailblazer Chris Foresta Latest GM News 24 12-28-2008 11:01 AM
Custom Lift and Suspension AlekG Off-Road 20 05-31-2008 07:35 PM
