Bose CD Player Swap - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 03-28-2011, 07:36 PM
futbolfever futbolfever is offline
2002 GMC Envoy SLT
Red Jewel Tintcoat 4.2L I6 AWD
Bose CD Player Swap
I currently drive a 2002 Envoy SLT with Bose audio system ....the 6 cd changer has stopped working as it does not load cds anymore .... I have a Bose 6 CD changer (which is identical from the deck in my envoy) from a 2004 envoy....
I was told that I could not just do the swap as the new cd player would have to be programed to my vehicle? is this true? If so, does anyone know how to do it ? or can I take it to a mechanic to get it done? Any help will be greatly appreciated....Thanks in advanced!
Old 03-28-2011, 07:38 PM
Me007gold Me007gold is offline
yes the new radio would have to be programed to your truck. All of our radios are VIN locked. You have to go to a dealer, or find some one with access to the tool.
Old 03-28-2011, 07:39 PM
Decembersend's Avatar
Decembersend Decembersend is offline
2003 Chevy TrailBlazer LT
Yes it will have to be reprogrammed and only a GM dealer can do it. I've heard it costing up to $150.
Marks 3" body/2.5" suspension lifts, HD Bilsteins, 1.5" Spacers, G80
David - Southeast Chapter Member
Old 03-28-2011, 07:53 PM
Boricua SS Boricua SS is offline
Yup you are correct, need to get it programmed from a dealer..hope it doesn't cost too much
Old 03-28-2011, 11:59 PM
Tolan Tolan is offline
2006 Chevy TrailBlazer LT
Black 4.2L I6 2WD
it will coast 1 hour of labor. Here in new orleans we charge $99 and hour so yep it will very on your location.
Old 03-29-2011, 10:51 PM
playstrings playstrings is offline
2003 GMC Envoy SLT XL
Pewter Metallic 5.3L V8 4X4
Bonjour ! From the frozen north. I have been reading a lot on this lately because I have been debating overhauling my whole system. During that I read that you can take the box apart and just replace the CD. So, I would be tempted to swap out the CD's between your 2 boxes and you will then not have to reprogram. FWIW >>>
Rick
Old 03-30-2011, 02:56 PM
2002 GMC Envoy SLT
I just got off the phone with a GM dealership ...will only cost $80 to reprogram but they do not guarantee it will work .... what are the chances of it working? pretty good? does any one have an idea? Thanks again for all your help!
Old 03-30-2011, 02:58 PM
from what I understand if it plugs into the factory harness, GM will be able to unlock it. Hopefully someone else will have more info
Old 03-30-2011, 03:32 PM
bromanjr's Avatar
bromanjr bromanjr is offline
Senior Member
2004 GMC Envoy SLT XUV
Indigo Blue Metallic 5.3L V8 2WD
The Bose system in an 02 is slightly different from the mid 04 and up. The amp was redesigned and the radio (HU) is not interchangeable. Although there is a rumor that a crafty person with a Tech II can change it over (reprogram??, not just clear the VIN).
Best bet is to check and match part #s to get the correct radio. Then get the VIN done with a Tech II.
Another option is to open up both radios and swap the CD changer to get yours working. I'm not sure they are identical, but probably.
182,000 and counting. Superchips 2914 Tune, NAV upgrade.
Old 03-31-2011, 09:05 AM
mwfaith1971 mwfaith1971 is offline
2002 Chevy TrailBlazer LTZ
Black Other AWD
Go on E-bay and you'll find a lot of repair services that will fix the CD part of the HU, or, you can get the CD mechanism and replace it yourself. If you want to replace the HU, get one for a full size truck, part #15184935 or 10357886.
Matt
You may not post new threads
You may not post replies
