Rear Ride height sensor on Envoy Denali - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Suspension Suspension
Old 04-01-2011, 05:49 PM
516NY_NVOY 516NY_NVOY is offline
2006 GMC Envoy Denali XL
Onyx Black 5.3L V8 4X4
My 2006 Envoy seems to go down in the rear at time over night. Not always but more times than not. Does anyone know where I can get a ride height sensor and can I do it myself?
Thanks from NY.
Old 04-01-2011, 05:54 PM
the roadie's Avatar
If it pumps back up in the morning to the expected height, your problem is not a sensor (which are off anyway overnight). It's bag, valve, or line leakage. Common problem with aging vehicles. Discussed plenty as well......
I would just hate myself if I let you buy a sensor and slap it in. Even on 4/1.
Old 04-01-2011, 05:59 PM
bromanjr's Avatar
bromanjr bromanjr is offline
Senior Member
2004 GMC Envoy SLT XUV
Indigo Blue Metallic 5.3L V8 2WD
The sensors (1 on each side) almost never fail. If the truck goes down while it is parked, it is not a sensor problem because the system is off.
Only an air leak can cause the rear to drop when parked.
Most reports are for bad air bags (original and aftermarket parts available)
Air Compressors also fail and occasionally air lines and fittings fail.
Soapy water in a spray bottle may reveal a leak, support the truck while you are under there, The system will stay pressurized even when jacked up, while you check for leaks.
Edit:I was too slow again.
182,000 and counting. Superchips 2914 Tune, NAV upgrade.
Old 04-04-2011, 10:33 AM
roadie and bromanjr thank you for the replies. I thought it was the air bags also but the problem is that the rear doesn't always drop. At times it will drop within an hour other times never or several hours like over night. If no leak revealed with soapy water how likely are the chances of it being a sensor issue?
Regards
Old 04-04-2011, 11:23 AM
the roadie's Avatar
Originally Posted by 516NY_NVOY View Post
... how likely are the chances of it being a sensor issue?...
Absolutely zero. The system powers off with the ignition. Sensors are not being looked at with the system off.
The air bags retain their pressure while the ignition is off only if the valves in the compressor assembly close fully. So if they have a problem, like dirt in the seat, then the pressure will leak out. Same with leaky hoses or bags. So if you have an intermittent problem that isn't revealed by soapy water spray, it's more likely to be the compressor valves than the bags.
Removing the bags for a good inspection isn't out of the question. But I'd be looking at rebuilding the compressor or if that's not your thing, buying one from Ebay or the Arnott replacement.
Old 04-04-2011, 09:37 PM
CSDenali CSDenali is offline
Dark Gray Metallic 5.3L V8 4X4
Mine sits noticeably lower on the passenger side. (rear) Thought it was me.. Until I measured. The rear end sits 1.5 inches lower on the passenger side. This, after about 10 minutes of sitting. I am also getting a lot of road noise now. By that, I mean it sounds like I have swampers on the truck. Tires are 8 months old, and have been fine. Can the air leak cause any rubbing issues? Hence, the moan I hear when rolling?
Thx
Old 04-14-2011, 02:47 PM
airboss airboss is offline
2003 GMC Envoy SLT XUV
Onyx Black 4.2L I6 AWD
Mine, too! It even rides that way. Will an out of adjustment sensor cause one side to ride lower?
Old 04-14-2011, 03:03 PM
bromanjr's Avatar
Senior Member
Unlikely a sensor adjustment if you haven't moved them.
Usually when only one side leaks down side or rides lower, it it something failing on that side. This could be the bag, the line or the Solenoid/Check valve in the compressor.
There is a solenoid/check valve for each side and they can operate at the same time or independently if needed.
Old 04-14-2011, 03:19 PM
The sensors WERE moved, to try to reduce the "Jacked up" look to something resembling normal. Following the first adjustment (by the dealership) I noticed that the pass side was down in the driveway and then down while driving. Do the sensors only operate the bag on their respective side?
Old 04-14-2011, 03:45 PM
bromanjr's Avatar
Senior Member
Yes, each side can independently signal too high (opens solenoid with compressor off) or too low (runs compressor then opens solenoid to raise). Usually they happen at the same time when you add or remove weight after key on or engine start.
I've heard of the system getting confused during adjustments, not sure what the fix has been. Try removing the fuse, or maybe jacking vehicle up to get them both to register high, then let down and see if the system picks up correct signals.
Finally, if they have been messed with and are way out of adjustment, put them both back to a central adjustment.
There is a procedure in the service manual to set "ride height". That process can be used with a modified dimension to get other than stock ride height. If one bolt has been removed, there is a larger adjustment range, but also a larger mis-adjustment possibility.
