Noise during acceleration - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 04-04-2011, 12:29 PM
simplesoft simplesoft is offline
2006 Chevy TrailBlazer LS
Summit White 4.2L I6 4X4
Cool Noise during acceleration
This is a 2006 TB LS 4X4 4.2L I6 with 196K. I am noticing a low frequency worble sound coming for the rear of the TB during acceleration, kinda like the sound you get from a bad tire. The sound disappears during coasting and deacceleration. I jacked up the rear and quickly checked for a bad bearing and noitced that I can move the drivers side rear wheel in and out slightly but does not do this on the passener side. Is this normal? I also checked the drive shaft u-joints and they look and feel OK however noticed the drive shaft at the transfer case end has a slight side to side play. Anyone have any thoughts as to what this acceleration sound could be?
Old 04-04-2011, 12:40 PM
the roadie's Avatar
Some in/out play is normal in axles due to the C-clips inside the differential that retain them. More than about 1/4" would worry me, though. Have you changed the transfer case fluid every 50K as required? Might indeed be a transfer case problem. There should be no play in the driveshaft, and a bad bearing might have killed the seal and the TC could be low or dry.
Old 04-04-2011, 12:43 PM
Thanks, I'll dig deeper into the TC.
Old 04-04-2011, 09:27 PM
Simon01's Avatar
Simon01 Simon01 is offline
2005 Chevy TrailBlazer LS
Superior Blue Metallic 4.2L I6 4X4
A noise on acceleration that disappears when coasting and deceleration is the classic indicator of a rear end issue also. Usually rear ends will make the noise in a particular speed range, like 40-45mph for example. Just sayin' that is another possibility.
