02 trailblazer STARTING PROBLEM - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 05-03-2011, 01:37 PM
bikeridercc bikeridercc is offline
2002 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 4X4
My 02 trailblazer recently had a new problem: when I turn the ignition key it clicks and won't start. It is intermittent. After a few tries it starts. The battery is less than a year old and I'm wondering what it could be.
Thanks in advance,
Bikeridercc
Old 05-03-2011, 01:44 PM
Boricua SS Boricua SS is offline
You might get better help and/or replies if you posted this in the right section.. not site support...Mods..help um out
Old 05-03-2011, 02:53 PM
Bill W's Avatar
Bill W Bill W is offline
2002 GMC Envoy SLT XUV
Summit White 4.2L I6 4X4
If you've checked to make sure your battery cables are tight my first guess would be the ignition switch.
They're inexpensive and fail often. Lots of threads on here about them.
Good Luck
Old 05-03-2011, 07:13 PM
2003 GMC Envoy SLT
Ignition switch. That's the same symptoms I had. Dealer replaced the switch under warranty.
Old 05-03-2011, 09:32 PM
petevw's Avatar
petevw petevw is offline
2002 Chevy TrailBlazer LTZ
too. Also, after you DO get it running, do a voltage check on the dash, and also w/ a voltmeter at the battery terminals.....should read approx. the same.
Battery terminals are tight, clean, & corrosion free?
Old 05-06-2011, 04:51 PM
dja3137's Avatar
dja3137 dja3137 is offline
white 4.2L I6 4X4
SAME PROBLEM HERE TOO!!!
its been so random the past 2 years...
Usually, i can twist the key 30-40 times and it will eventually start
but May 1st, 2010, i had to get it towed...and the car started once it was dropped off
May 1st, 2011, i had to get it towed again, and i drove it off the flatbed after a $200 charge!
everything comes on, lights, radio, fuel pump, etc; yet no start..i hear a click, but its actually the throttle body..not the starter....
so frustrating...
but you guys are saying its the ignition switch?
fyi, i replaced the battery last year and have no corrosion
Old 05-06-2011, 05:42 PM
the roadie's Avatar
Ignition switch, starter relay, wiring, or starter. Judging by the failure rate, start with the switch, then dig deeper if you have to. Try to catch it in the act with a meter.
Old 06-06-2011, 12:27 PM
dja3137's Avatar
white 4.2L I6 4X4
Purchased a new ignition swithch...but was waiting for it to happen again to see if it was indeed the switch...well, one month later...this morning...no start...I rip my ignition switch out at 630am..and put the new one in...still no start...come home for lunch...still no start...
Ill be checking all my cables when I get out of work...but I'm sure they are fine...
Do I go buy a new starter for $180 to "see" if that's the problem or what?
Old 06-06-2011, 06:16 PM
c good c good is offline
Senior Member
2002 GMC Envoy SLT
At this point it's either a bad selenoid(relay) or bad starter motor. Sometimes all you need to do is clean the contacts on the selenoid (if it's serviceable on this model). Otherwise you might as well go with a new starter or have your existing one rebuilt. HTH c good
Old 08-02-2011, 08:38 PM
Remington8904 Remington8904 is offline
2004 GMC Envoy SLE
Intermittent starting issue... Already on 2nd ignition switch
Hey guys I have a 2004 Envoy with the 4.2I6. I am having the common intermittent starting issues. I am on my 2nd ignition switch.... I replaced it the first time at 76,000 and within the next month I was having the same issues again. So I replaced the ignition switch again and that fixed the symptom for about a week. My wife was out with out baby today and it wouldn't start again.... Some one jumped the battery and it started right up. I had the battery tested when I replaced the ignition switch both times and it was good. The cables are tight with no corrosion.
When I was diagnosing the problem the first time, I was not getting 12v to the starter when they vehicle was not starting. All I was getting was clicks... The same thing that is happening now. I am pretty sure that two switches should not have gone bad that quick. I was reading about the fuse box going bad? I hope it's not the starter... That looks like a pain to get too. But I don't think that is culprit. Any help would be awesome.
