HID headlight problem - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Engine Tunes/Mods
Engine Tunes/Mods Performance Engine Tuning/Engine Modifications
Old 05-18-2011, 04:48 PM
ayotte ayotte is offline
2007 Chevy TrailBlazer LT
Summit White 4.2L I6 4X4
Hi guys. I have something weird going on with my after market HID headlamps. I recently ran the battery dead and had to boost it. I got a pretty good arc when i attached the negative to my engine block. Since then my low beam bulb will only work the first time I start the trailblazer each day. Every consecutive time that I start it the low beam on the passenger side will not work. It will not work with the interior switch or when I put it in gear. I have replaced the bulb and swapped the ballast from the working headlights and still no go. The fuses all check out good and I also replaced them. I also disconnected the negative cable on the battery for ten minutes to see if it helped but no dice.
Any help you could provide would be awesome. Its a 2007 LT with the 4.2 I6
Thanks
Ayotte
Old 05-18-2011, 07:42 PM
ej_bennallie's Avatar
ej_bennallie ej_bennallie is offline
2005 GMC Envoy SLE
Tan/Gold 4.2L I6 4X4
Do you have a wire harness attached to your ballast? If not you should get one. This would send power over to your Passenger side.
TollKeeper TollKeeper is offline
2004 GMC Envoy SLT XUV
Liquid Silver Metallic 5.3L V8 4X4
Do you use the relay system for your headlights, or are they direct wired into the OE wiring?
If you have a relay, I would probly suggest checking the wiring, and the relay, and the ground for the relay.
If you dont have a relay, I would suggest you get one.
Brian
04 GMC XUV - 104k Miles - G80 with 3.42
01 Pontiac Aztek GT AWD - 90 Pontiac ASC McLaren Turbo Grand Prix
Old 05-18-2011, 07:44 PM
Boricua SS Boricua SS is offline
.. if you hve the relay harness, thn trouble shoot that..if not, check your factory wiring harness to see if it burnt up
Old 05-18-2011, 07:47 PM
The headlights are just wired into the the OEM wiring and i cant see anything wrong at all with that or the ballast.
Old 05-18-2011, 07:49 PM
2005 GMC Envoy SLE
id just grab a relay, but if u wanna find the problem, you have some research to do.
Old 05-18-2011, 09:20 PM
Ok thanks guys I will see what I can figure out
Ayotte
Old 05-19-2011, 01:22 PM
efi-diy efi-diy is offline
Senior Member
1951 GMC 3100 PU Truck
hot rod black turbo'ed 4.2L I6 2WD
HID head light problem == engine tune /mod ????
must be some new fangled ignition - HID otherwise why is it posted in the engine tune/mod section????????????
Turbo'ed 4200 @ 10 PSI == 510 RWHP 500 LB/FT Torque Rear wheel
Old 05-22-2011, 05:17 PM
Dudirt's Avatar
Dudirt Dudirt is offline
blue 6.0L LS2 V8 AWD
hid problem
I had a similar problem with mine also when i first got them the would blink & flicker what i did was add a relay harness & also up grade my ballast to digital ballast from a analog one
Old 05-22-2011, 09:47 PM
smokintrailblaz's Avatar
smokintrailblaz smokintrailblaz is offline
2004 Chevy TrailBlazer LS
Black 4.2L I6 4X4
Do you actually need a DRL modifier/killer? Would a harness and HID kit be enough. I dont mind turning the switch all the way to the left everytime. The DRL thing seems way over my head.
