2004 Envoy - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 05-22-2011, 03:59 PM
kevinrwarren kevinrwarren is offline
2004 GMC Envoy SLE
Summit White 4.2L I6 AWD
2004 Envoy
I wasn't sure what forum to put this in so here is my queston. My check engine light has been on and I got a pint off from my local parts place of what it could possibly be and have replaced everything on the list except the thing dealing with a vacuum leak can anyone tell me how to fix this myself thanks
Old 05-22-2011, 04:23 PM
freddyboy61 freddyboy61 is offline
2004 GMC Envoy SLE XL
Summit White 4.2L I6 4X4
Welcome to the site, but please be a little more careful in your typing. I had to read your post several times to realize the "pint off" actually meant "print out".
In order for anyone to help you with your problem, you need to provide more information such as the trouble code that the parts store read from your vehicle and any symptoms you are experiencing.
[SIZE="2"][I]Freddyboy61[/I][COLOR="Blue"][/COLOR][/SIZE]
[U] [/U]
Old 05-22-2011, 04:52 PM
2004 GMC Envoy SLE
Thanks for the spell check the codes are PO106 , PO410 if Im looking at the print off correctly
Old 05-22-2011, 07:30 PM
the roadie's Avatar
Lots of discussion here on those two codes. Run a search, and spell them with a P and a Zero then the number instead of P and O, and you'll find a lot to read.
And what precisely did you replace? If you didn't troubleshoot the Secondary Air Injection system properly, you might have replaced a $250 air pump when it might have been a $50 O2 sensor or $25 relay.
Old 05-22-2011, 10:40 PM
2004 GMC Envoy SLE
2004 Envoy
I replaced the map sensor , variable time cam sensor , thermostat , air filter ,and i had the Secondary Air Injection system checked and and someone told me that it could be a vacuum leak under the dash
Old 05-22-2011, 11:05 PM
the roadie's Avatar
There is nothing under our dash that requires vacuum. Whoever guessed that should be disregarded as not knowing enough about our platform.
