Check Engine Code P0014 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 05-22-2011, 08:53 PM
DuelingWarwicks DuelingWarwicks is offline
Envoy Envoy Envoy SLT
Black Granite Metallic 4.2L I6 AWD
Check engine light just came on.. Autozone test generated P0014 code. Definition: ECM has detected the camshaft phase angle has exceded its tolerance value, Probable cause: Loose cam or crank sensor, excessive timing chain free play, blocked oil passage in the camshaft actuator assembly or engine, incorrect oil quality or viscosity
Couple things: I spent the day towing a u-haul 5x8 trailer, well within the limits of the vehicle's capacity and I have been using 87 grade gas and just filled it with 93 that morning. Also, I am down to about 12% on the engine oil life according to the DIC.. Anyone else have this? I'm thinking change the oil and switch back to 87 and see what happens?
Old 05-22-2011, 08:56 PM
polar's Avatar
polar polar is offline
2002 Chevy TrailBlazer LTZ
Black 4.2L I6 4X4
I'm pretty sure the switching gas shouldnt be a problem cause on my snowmobile i usually run 93 due to high performance parts but if the price is a lot more i run 87 no problems.
2002 Chevy Trailblazer LTZ
Debadged:Matched Bowtie
R.I.P. 7/18/2011
Old 05-22-2011, 09:24 PM
sn8bite's Avatar
sn8bite sn8bite is offline
2006 Chevy TrailBlazer LT
change the oil.use a high quality oil such as penzoil. the actuator gets clogged, and dosent function as its design to. may take a couple of changes to clean it.also change the oil at no less then 25% life left.i had this happen to me and i did what i outline for you and havent had a problem since.
Old 05-22-2011, 09:33 PM
sn8bite's Avatar
this is the actuator. the screens get dirty and cloged Name:  getimage.jpg
Size:  7.5 KBand throws code p0014
Old 05-23-2011, 09:41 AM
XUVFISCH's Avatar
XUVFISCH XUVFISCH is offline
2004 GMC Envoy SLE XUV
I had the same thing happen to me a couple years ago, I took the actuator out, cleaned it, one of the screens fell out, I put it back in the voy and it ran even worse. Went to the dealership and bought a new one for like $90.00 Ran perfect after that. I think you can get them cheaper online, but I needed it asap.
I tried changing the oil and all that stuff, but it didn't work. replacing the the actuator is very easy.
Old 10-20-2011, 03:36 PM
turkish6 turkish6 is offline
2004 Chevy TrailBlazer LS EXT
Black 4.2L I6 4X4
Any links or tips to actuator location and replacemnt write-up
Old 10-28-2011, 04:32 PM
jdr00ejr jdr00ejr is offline
2005 GMC Envoy SLE XL
Silver Mist Metallic 4.2L I6 4X4
Was just reading this 19 page thread. Here you go...
http://forums.trailvoy.com/showthread.php?t=62398
Old 12-21-2011, 03:19 PM
jpo jpo is offline
2003 Chevy TrailBlazer LT
Superior Blue Metallic 4.2L I6 4X4
P0014
A friends Envoy was consisitanly throwing new P0014's. After reading posts here, we tried an oil change. It worked!
Old 12-21-2011, 05:33 PM
Where is the actuator? My engine light came on again and I suspect it's the same again (will check first). Still 50% right now on oil life
Old 12-21-2011, 05:38 PM
jpo jpo is offline
Sensor is on right front of engine pointing forward. Actuator is on right front pointing to the right. Right/left is front sitting inside the vehicle.
