Reduced Engine Power Light/Loss of Power - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 06-05-2011, 11:31 AM
trailblaze04 trailblaze04 is offline
2004 Chevy TrailBlazer LS
I have an 04 Trailblazer 2WD and recently it has lost power twice while driving. The first time it happened the Reduced Engine Power light came on but the second time it didn't. I have noticed on both occasions I had just started it up and not driven a mile when it happened. I turned the engine off and restarted it and it was back to normal.
I went to get it checked out but they said they couldn't fix it and gave me a code. They said someone more qualified should look at it so now I'm trying to figure out what to do. The code is P1680.
Has anyone else dealt with this problem?
Also, I have noticed that when I start it up after sitting awhile I have to let it sit a few minutes because if I drive it right after starting the engine it will rev up when I pull out of the drive.
Old 06-05-2011, 11:42 AM
truefire98's Avatar
truefire98 truefire98 is offline
1999 GMC sierra ls 1500
Majestic Red Metallic 5.3L V8 2WD
normally its related to the t/b and the accelerator pedal because the system is drive by wire, and there is no throttle cable, so ether the pedal is bad or the t/b is bad, and even sometimes the computer needs a reflash to update the problem. best bet is to take it to a dealer to see what is going on.
Old 06-05-2011, 12:07 PM
the roadie's Avatar
Many discussions here mention that code.
Old 06-05-2011, 12:08 PM
christo829's Avatar
christo829 christo829 is offline
2004 Chevy TrailBlazer LT
Take a look at these two threads:
http://forums.trailvoy.com/showthrea...ighlight=p1680
http://forums.trailvoy.com/showthrea...ighlight=P1680
In that second thread, there's a resistance value listed for the APP. If you're
handy with a multimeter, you could check that. If it's bad, replace it. If
it's good, then could be solvable with a PCM reflash/update. Or...maybe a good excuse
to get a PCMforless tune...
Some members have found a throttle body clean to help as well:
http://forums.trailvoy.com/showthrea...ody+cle aning
Good Luck!
