Hi TrailVoy enthusiasts:
I installed LEDs replacing the eight OEM bulbs (dome lights, 2 each door) in my Envoy 2004, L6. Now my dash/instrument panel illumination is not working.
I did check the following fuses and they all are OK:
Under hood
#24
and all others
under the driver side rear seat
TBC2 fuse #7
TBC5 fuse #32
and all others.
I found blown-out and replaced fuse #4 under driver rear seat.
Instruments work well and radio illumination dims OK, it only the dash/instruments panel illumination that does not work.
What could be causing this problem?
Thanks, Ed
Under hood
#24
and all others
TBC2 fuse #7
TBC5 fuse #32
and all others.
Thanks, Ed
