help w/ oil pan removal - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 07-04-2011, 07:54 PM
blackcar blackcar is offline
2002 GMC Envoy SLE
Black 4.2L I6 2WD
can i or do i need to take this off to drop the oil pan, i really need to get it completely off the car.
Old 07-06-2011, 11:09 PM
Mooseman2's Avatar
Mooseman2 Mooseman2 is offline
2002 Chevy TrailBlazer LT EXT
Black 4.2L I6 4X4
I think no.7 says so...
1. Remove the A/C compressor bottom bolts and loosen the top bolts.
2. Remove the oil level indicator and tube.
3. Raise the vehicle. Refer to Vehicle Lifting.
4. Remove left and right front tire and wheel assemblies.
5. Remove the engine protection shield mounting bolts.
6. Remove the engine protection shield.
7. Remove the steering gear crossmember, front.
8. Remove the left and right wheel drive shaft.
9. Remove the front drive axle clutch fork assembly.
10. Disconnect the prop shaft from the front axle pinion yoke.
11. Remove the oil pan drain plug and drain the oil.
12. Unclip the transmission cooler lines from the engine block.
13. Remove the front differential bolts and set aside the front differential.
14. Remove 4 transmission bell housing bolts that are attached to the oil pan.
15. Remove the remaining oil pan bolts.
16. Place 2 oil pan bolts in the jack screws on the oil pan and tighten evenly to release the oil pan from the engine.
17. Clean and inspect the oil pan.
Old 07-09-2011, 12:02 PM
2002 GMC Envoy SLE
Black 4.2L I6 2WD
i was hoping i wouldn't have to, i took all the bolts out, but it looks like pressure from the frame is on the car...didn't want to removed something that might make the car loose its structure and fall...on me!!! lol. thanks for the tips and guide.
Old 07-09-2011, 06:10 PM
the roadie's Avatar
Motor mounts are going to keep the engine from falling.
Old 07-09-2011, 11:45 PM
Mooseman2's Avatar
Black 4.2L I6 4X4
Crossmembers like these usually just stiffen the frame up while others do hold things up, like the transmission crossmember. In this case, I wouldn't worry about it, especially since the manual says to remove it.
Old 12-26-2011, 09:33 PM
slara02TB slara02TB is offline
2002 Chevy TrailBlazer LS
Indigo Blue Metallic 4.2L I6 2WD
Does the rack and pinion have come off???
Old 01-12-2012, 12:21 AM
sixholdens sixholdens is offline
Oil Pan
No you do not need to take the rack and pinion out to get the oil pan out.
Old 04-02-2014, 06:29 PM
taterheadrick taterheadrick is offline
Lurking Newbie
How do you get the front rear end apart from the oil pan?
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
tricky1
