can't shift out of park/button stuck - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > The Lounge > Introductions
Introductions Welcome to TrailVoy.com! Tell us about yourself, your vehicle, mods, location etc. (no tech questions)
Old 07-27-2011, 10:16 AM
daveb04 daveb04 is offline
New Member
2004 Chevy TrailBlazer LT EXT
Dark Green Metallic 6.0L LS2 V8 4X4
Been having an occasional problem with shifting out of park. The button won't push in. Sometimes if I turn off and restart, it will push in. Last night it wouldn't at all, and then this morning it did. Is there any kind of override for this? I have a 2004 Chevy Trailblazer. I did see another post on this. My husband is going to try to look at it and see if it's something he can fix.
Old 07-27-2011, 10:46 AM
the roadie's Avatar
There's a solenoid in the console that may be sticking mechanically, but sometimes what you have is an early warning of flaky behavior of the ignition switch. Easy and cheap repair.
http://forums.trailvoy.com/showthread.php?t=61278
Old 07-27-2011, 02:16 PM
New Member
Thanks for the replies!
Old 07-27-2011, 10:23 PM
CdnGMan's Avatar
CdnGMan CdnGMan is offline
2006 Chevy TrailBlazer LT EXT
Welcome aboard...
Good luck!
Toronto, Ontario
Old 07-28-2011, 12:34 PM
New Member
About the override button.....I did find it. Is that a one-time override only when it gets stuck or does it override it completely so it won't get stuck at all? I don't know why they don't tell you about this in the owner's manual, or at least at cust. service.
Old 07-28-2011, 12:51 PM
christo829's Avatar
christo829 christo829 is offline
You can disconnect the solenoid, but it would be best to try to figure
out where the bind-up is occurring. The solenoid may be sticking, you may be
getting an intermittent electrical circuit failure (either in the wiring or from the
interlock switch), or there may be something getting in the way of the
link between the button and the solenoid.
Good Luck!
Old 08-02-2013, 03:49 PM
meyle meyle is offline
New Member
2006 Chevy TrailBlazer LS
Silver Mist Metallic 4.2L I6 4X4
Shifter button stuck in park
Sounds like I'm not the only one with this problem. It happened first 3 weeks ago and I fixed by taking key out and reinserting; it fixed it for about 2 weeks. It got stuck again and the "take the key out trick" didn't work this time so I pulled the console apart and found the release button. I did some research on here and narrowed it down to either the interlocking solenoid, brake light switch or accuator (after running through the fuses mentioned). I took it in to the dealer and they just called saying I need a new shifter handle and button for $400. I'm skeptical about their diagnosis as everything on here mentioned 1 of the 3 things I listed above and now they say a shifter handle? anyone have any advice?
thanks
Old 01-13-2015, 09:05 PM
Gulfsurfer Gulfsurfer is offline
New Member
2006 GMC Envoy SLT XL
Summit White 4.2L I6 2WD
Same problem here, 2005 Envoy. Found a lot of info, seems to be a common problem; either ign switch, brake switch or solenoid in shifter assembly. See the following thread for more info (yah, it's a SSR forum, but it's the same system):
http://www.ssrfanatic.com/forum/f5/s...ictures-57351/
There's a pic from that thread that show's the location of the override button (round silver button below the shifter shaft). I lifted the pic but don't know yet why I can't post that pic.
Anyway, it's cold now, wifey needs the car and I don't have time to do the final diagnosis. So I came up with a way for her to override it without lifting the shifter handle boot and using a 90deg tool to depress the manual override button (kind of awkward to do).
I approximated the location of the override button on the outside of the console, and drilled a 3/16" hole. Now wifey can just stick a very small phillips screwdriver in the hole, find the override button by feel, depress it and shift out of Park!
Sorry I can't post pics, I'm not sure what i have to do.
