Random cylinder Misfire - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Engine Tunes/Mods
Engine Tunes/Mods Performance Engine Tuning/Engine Modifications
Old 07-30-2011, 04:12 PM
Kevin32 Kevin32 is offline
2002 GMC Envoy SLE
Pewter Metallic 4.2L I6 4X4
On my 2002 GMC Envoy I got a random cylinder misfire reading. I changed all six spark plugs and the crankshaft position sensor. Still runs rough though. SES light is blinking. Any ideas of what to fix next?
Old 07-30-2011, 05:59 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
You probably have a bad coil.
Dozens of threads on the subject, including one, or two, on changing the coil.
Give the SEARCH function a spin.
Good luck
Ray
Old 07-30-2011, 09:56 PM
GfabSabfd's Avatar
GfabSabfd GfabSabfd is offline
2002 Chevy TrailBlazer LT
Summit White 4.2L I6 4X4
Ooohhhhh,just had same the same problem 6 mos ago. Multi misfire. Purchased 2 new coils,swapped one out then tested with OBDII. Kept testing until the meter told witch cylinder was misfiring. Repaired 1st and 3rd coil pack from front of truck. 1mos ago happened AGAIN! Had to change remaining 4! I bought them at several auto zone locations,cause they only stock one or two. They go for about 65-70,a piece. Truck runs awesome! Did these,new plugs,and throttle body cleaning. Truck is BEAutiful. Good luck trouble shooting, definately need a meter to isolate multi misfire code. Once ya know which cylinders are defective it is an easy fix. 10mm socket for the coilpacks and breather cover,and throttlebody.http://forums.trailvoy.com/showthrea...t=48277&page=2. This thread may help.
Old 07-30-2011, 10:23 PM
petevw's Avatar
petevw petevw is offline
2002 Chevy TrailBlazer LTZ
Most likely bad coil pack(s). Since it's a 10 yr old vehicle, I'd recommend changing all six coils......should take care of the problem. I had same issue w/ blinking SES light.....replaced all coils, problem disappeared.
BTW, what plugs did you put in it?
Oh, and double check to make sure you seated the tip of the coil pack straight down and onto the spark plug.....the coil CAN be inserted slightly crooked and not touch the plug.
Old 07-30-2011, 10:34 PM
2002 GMC Envoy SLE
Random misfires
I took the clip off the Camshaft Position Actuator, and it had oil on the female end. Cant find where to buy a new one though. Or if it is even called a Camshaft Position Actuator
Old 07-30-2011, 10:35 PM
2002 GMC Envoy SLE
I put in 6 new AC Delcos.
Old 07-30-2011, 10:37 PM
petevw's Avatar
Which ones? Reason I ask is that these engines seem somewhat sensitive to plugs.
Old 07-30-2011, 10:51 PM
2002 GMC Envoy SLE
Plugs
I put in #41-103's AC Delcos. Would changing the Camshaft Position Actuator Solenoid help too?
Old 09-20-2011, 10:17 PM
Gevans17 Gevans17 is offline
2004 Chevy TrailBlazer LS
Dark Green Metallic 4.2L I6 2WD
where to buy exhaust cam actuator
check rockauto.com
Old 09-25-2011, 11:45 PM
Timmyblazer33 Timmyblazer33 is offline
2002 Chevy TrailBlazer LS
Steel Gray Metallic 4.2L I6 AWD
Changed All Coils
Hey guys,
I had the same problem and I changed all plugs and coils. However, I am still getting a multi random misfire. I don't know what to do?? Any Suggestions??
