Part number help please - rear plate holder - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-08 SS General Tech Q&A > General
Old 08-01-2011, 09:29 PM
Torontoboy Torontoboy is offline
2007 Chevy TrailBlazer SS (3SS)
Black 6.0L LS2 V8 AWD
Hi everyone…
I hope that someone could lean in and help here.
I am looking for the part # for the Part -> rear plate holder.
---> 2007 TBSS
2 of the 4 studs are busted on mine (not too sure why)…
It is the back large plastic plate holder (rectangular).
Thank you!!
Frank
Old 08-01-2011, 09:32 PM
trailblazingold's Avatar
trailblazingold trailblazingold is offline
2006 Chevy TrailBlazer LS
Singularity Silver 4.2L I6 2WD
88980652
Old 08-01-2011, 11:28 PM
Thanks!!!!
Quite the quick reply....
Do you know if GM sells them colour coded to your car or? how does it work?
Thanks again!!
Frank
Old 08-01-2011, 11:45 PM
You will have to get it painted. Unless you find one on ebay.
Old 08-02-2011, 12:16 AM
DJones DJones is offline
Senior Member
2003 Chevy TrailBlazer LTZ
Summit White 4.2L I6 4X4
Or you could do it better and de-brand one from a Rainier or 9-7x to give it a much sleeker look.
Old 08-02-2011, 12:19 AM
hmmmmmm...
i will check to see hoe the rainer looks or how is it different
I have also located a local dude here that has a plate insert on Kijiji.
If this goes thrugh then i will be ok.
thanks
Frank
Old 08-03-2011, 04:06 PM
---> Can anyone confirm if the GM 15191415 part will fit a 2007 TBSS???
Thanks
Frank
Old 08-03-2011, 04:12 PM
http://www.compnine.com/index.php?name=15191415
Old 08-03-2011, 04:28 PM
I have seen that link -> thanks
The part seems identical to the 2007 version...
Is there a way to confirm...as the 2004 seems to be exact same as the 2007..
Thank you
Frank
Old 08-03-2011, 04:37 PM
No, it's for a Buick, it will not fit. You can use a Envoy or a Trailblazer one only.
