Front/rear struts/shocks Replacement Cost? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Suspension Suspension
Old 08-09-2011, 11:18 AM
mikepc2fla's Avatar
mikepc2fla mikepc2fla is offline
2002 GMC Envoy SLT
Pewter Metallic 4.2L I6 4X4
Was quoted @ $700 to replace front/rears with Monroe SensaTrac's with alignment....does that sound right? Seems kind of high to me.And I know some will say it's easy to replace, DIY,but I don't have the time/tools/patience to do it myself. Any opinions on the cost est??
Old 08-09-2011, 11:23 AM
the roadie's Avatar
Sort of OK. You can check their cost on shocks at summit racing or rockauto web sites. Typically $60-75 each and they don't pass on any wholesale savings on to you. A good shop with a wall-mounted spring compressor is going to take under an hour per side for the fronts, and 15-20 minutes for each rear. Let's say three hours max for labor. And a $60 alignment. You can certainly do the math, and call around for other quotes. If you were in a northern salt-using state, there would be a surcharge for the annoyance of rusted-on fasteners.
Old 08-09-2011, 11:40 AM
mikepc2fla's Avatar
2002 GMC Envoy SLT
Thanks for the quick response...going to call 2-3 other places later and see if they're close to it.
Old 08-09-2011, 12:04 PM
mikepc2fla's Avatar
2002 GMC Envoy SLT
Had the first place fax me the estimate (Tire Choice) here's the breakdown. Labor is fine, but seems to me the parts are double.
Monroe Sensa-Trac Shocks=$99.99 each=$198.98
Monroe Sensa-Trac Struts=$139.99 ea.=$279.98
Labor=$150
Total=$664.96 plus tax/shop supplies=$704.86
ouch
Old 08-09-2011, 12:42 PM
markarock's Avatar
markarock markarock is offline
Senior Member
2006 Chevy TrailBlazer LT
Red Jewel Tintcoat 5.3L V8 4X4
You can buy the rears much cheaper at Rock Auto, and put them on yourself easily--in only half an hour. That will drop your overall cost significantly, and not take much time out of your day. They do the hard work, you do the easy work. Makes sense to me.
Mark
3.73; G80; Bose; XM; DIC
Old 08-09-2011, 12:44 PM
Me007gold Me007gold is offline
You should ask them if you can bring your own parts, also ask then what shop supplies they are using? the kit will come with everything you need. I doublt they are going to use $40 in towels and wd-40
Old 08-09-2011, 12:52 PM
busterbrown's Avatar
busterbrown busterbrown is offline
1900 Santa's Reindeer
Red Other 4X4
Labor=$150
ouch
Go to AAP website and purchase the sensa tracs as a pickup order. Use coupon code DEALIO and break up your order for each side (1 shock and 1 strut). I paid $92 per side for a total of $184. Install the rears yourself as others have mentioned. If you can boil water, you can install shocks. Then find yourself a reputable, honest service location and pay them man hours for the struts. I paid $97 for the installation of the fronts using my existing springs. Done in 2 hours. Total damage was $280. As far as $700, I'd run away as fast as I can. Hope this helps.
Old 08-09-2011, 12:55 PM
the roadie's Avatar
Originally Posted by busterbrown View Post
...If you can boil water, you can install shocks....
Post of the day for me, and the day's early!
Gives me an idea, though.....
Old 08-09-2011, 01:45 PM
mikepc2fla's Avatar
2002 GMC Envoy SLT
Thanks for the coupon code...nice little $300+ savings!
Old 08-12-2011, 11:57 AM
canam's Avatar
canam canam is offline
2005 GMC Envoy SLE
Liquid Silver Metallic 4.2L I6 4X4
I was just quoted the same price . But looking around i found that monroe sells a quick strut part number 171341 or the cheaper one is a 181341 . They are a compltete unit no need to take apart springs or anything un bolt old bolt in new . has anybody ever used these yet . I found a set of the cheaper one for 180 bucs for the pair free shipping .
