so i need to know the normal value must be between
Fuel Sys 1 __________ CL (closed/open loop)
CALC Load (%) _______ 35.2 (normal dep on engine speed and throttle position and map values)
ECT (F)______________ 181 (engine coolant temp. this is low if your vehicle is fully warmed up. Normal if just starting to warm up. It should be around 195F at full operating temp.
STFT B1 (%)________ -3 ~ -13 (short term fuel trim)
LTFT B1 (%)________ 21.8 (llong term fuel trim)
MAP ( inHG )__________ 9.1 ~ 11.5 (this is absolute pressure not vaccum. Atmospheric pressure 29.5 minus engine vaccum ~21. You should have 8-8.5 Hg at idle)
Eng RPM _____________ 907 (normal if off idle. Idle should be 600-650 rpm)
Spark ADV (ْ) ________ 7 ~ 19
IAT (F) ______________ 156 (this seems high but then again my IAT is at 130F at idle and fully warmed up. We need to investigate this)
TPS (%) _____________ 8 ~ 12.9 (This looks normal. However on my Envoy I see my throttle position at idle is at 32%. I need to investigate this more)
O2S B1 S1 (V)_______ 0.850 (Looks ok but you need to check when this goes high and then low to see if the O2 is reacting to the injector pulses. Need an O-scope or chart view to see changes over time)
STFT B1 S1 (%)_______ - 10.9 ~ 0 ??
O2S B1 S2 (V)________ 0.700 ??
STFT B1 S2___________ NA
MIL DIs ( Mile )________ 0 (No Check engine lights)
what are the normal values for all
You first step is to connect a vacuum guage to see if you really have a leak. Let us know what the reading is at idle.
Related Threads
1.3M posts
173.5K members
Since 2004
