Rear Window wiper motor - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Appearance > Interior
Interior Interior
Old 09-04-2011, 10:05 PM
anthonyl79 anthonyl79 is offline
2005 GMC Envoy SLT XL
Superior Blue Metallic 4.2L I6 4X4
I have a 2005 rear window wiper that has decided to stop working. Its parked in the right spot. I'm looking for the wiring diagram so I can check this out. I have no power at the rear wiper motor. Hope someone can help. Thanks!
K&N filter,Kenwood deck,Jl Audio 6.5 cs in front powered by Kenwood 400 watt,Kenwood 12" sub w/Sony Explod 800 watt amp.
Old 09-04-2011, 10:17 PM
Originally Posted by blckshdw View Post
Check out this thread, it might help you
Awesome thank you for the help!
Old 09-04-2011, 11:01 PM
christo829's Avatar
christo829 christo829 is offline
2004 Chevy TrailBlazer LT
One other thing to check is the wiring where it passes from the body to the rear hatch.
Inside the rubber sleeve/boot, sometimes the wiring can get broken, but still appear
intact.
I assume you've already checked the fuse?
Good Luck!
Old 09-04-2011, 11:23 PM
intact.
Good Luck!
WOW thanks! Went and checked and guess what!! Wire broken above door in the grommet. Love this forum. Thanks for all the help. So nice getting things fixed right away!
Old 01-10-2012, 07:03 PM
tcrossley tcrossley is offline
2005 Chevy TrailBlazer LS EXT
Summit White 4.2L I6 4X4
Rear wiper inoperative.
So I have had a total of 3 issues recently with the tailgate in our 05 TB. Over a year ago the lock stopped working on the tailgate allowing anyone to open it, setting off the alarm. It no longer locks with the remote or with the button on the drivers door. Then recently the rear wiper stopped working and then shortly thereafter the rear defroster stopped working. I finally got the urge to start digging and here is what I found.....
I checked the wires as they came through the rear grommet, they were fine. I checked the fuses, they were fine. So i tore the rear trim off of the liftgate to track down some wires. Of course they all go in to a module so i decided to pull all 3 plugs off of the module and I found 2 wires in one plug melted together. I removed the black casing from around these wires and wrapped each individual wire with tape so they did not contact each other and plugged them back in. My rear defroster works again but my electronic latch assembly is still inop and needs to be replaced. The rear wiper WASHER works but the wiper motor itself is frozen up. So I fixed 1 out of 3 things. The other 2 issues will be fixed soon by replacing bad parts.
