How to hook up trailer lights to Envoy - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > The 02-09 "How-To" and DIY Section
The 02-09 "How-To" and DIY Section Threads on Do-It-Yourself and How-To goes here.
Old 09-13-2011, 12:20 PM
OldMike OldMike is offline
2005 GMC Envoy SLT
I have an 05 GMC Envoy SLT with towing package and have never towed with it. I just bought a used 4X8 little trailer to haul riding mower. I need to hook up the flat 4 pin connector on the trailer to the round GMC plug. Any one have a pinout of the truck plug?
Thanks, Mike
Old 09-13-2011, 12:28 PM
bartonmd's Avatar
bartonmd bartonmd is offline
Basic Vendor- Skid Plates
2007 Chevy TrailBlazer LS
Thanks, Mike
um... You go to WalMart, any auto parts store, most hardware stores, any tractor supply type store, or even some truck stops and gas stations, and buy a 7-pin to 4-pin connector adaptor...
Mike
The GB ended, but PM me if you want one!
GB also ended, but PM me if you want these!
Old 09-13-2011, 01:27 PM
the roadie's Avatar
And the pinout of the receptacle is molded into its plastic flap cover. And available through Googling for "Bargman trailer connector" (Bargman being the nickname of the standard 7-pin RV trailer connector). Been posted and discussed quite a few times on trailvoy as well.
Old 09-13-2011, 04:53 PM
2005 GMC Envoy SLT
Thanks, Guys. Did a search but didn't find the pinout. Also too dumb to see the pinout on flap. Was going to be cheap and wire it myself, but if the adapter isn't too pricey, that's the way to go.
Thanks Again, Mike
Old 09-13-2011, 04:55 PM
bartonmd's Avatar
Thanks Again, Mike
The adaptor is like $7.00 and available everywhere...
Mike
Old 09-13-2011, 05:14 PM
muddy tires's Avatar
muddy tires muddy tires is offline
Senior Member
2005 Chevy TrailBlazer LT EXT
I've wired them myself in the past, but generally only if I need an extended pigtail (the TB plug is a bit of a stretch to the side).
Old 09-13-2011, 05:27 PM
the roadie's Avatar
$13 even at UHaul (not the cheapest) but this one has a light in it.
Old 09-14-2011, 09:50 PM
PAblzr PAblzr is offline
2002 Chevy TrailBlazer LS
Originally Posted by bore_pig View Post
I .... make an extension cord to go between the truck and trailer in that situation.
The TB does require an extension cord for some of the things it ends up towing. I keep it, the seven pin to 4 pin adapter, a spare 5/8" diameter hitch pin w/ clip, an 18 inch length of chain & some threaded chain links ( to extend too short safety chains), and a pair of older style tail light bulbs that are still common on small trailers in the little compartment in the left rear interior panel at all times.
I have also learned over the years that no matter how positive a friend says he is about the size of the coupler on his trailer it is best to take a 1-7/8 and 2" ball with you when picking up a trailer you have not towed before.
PAblzr
If you see it on the internet it must be true. That's the law isn't it?
Old 09-15-2011, 01:01 PM
Senior Member
I typically use a proper adapter and make an extension cord to go between the truck and trailer in that situation. Why mess with the factory harness if you don't have to?
No. I didn't change the factory harness. I made an extension with a male 7-pin connecter at one end and a flat 4-pin at the other.
Old 09-15-2011, 04:11 PM
Good DIY solution! Why didn't I think of that? What you did is exactly the kind of thing I come to Trailvoy to learn so 1) I spend less money and 2) I do not have to rely on others to solve all my problems.
PAblzr
