Timing chain noise? 2002 170k miles - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 09-19-2011, 01:52 PM
bboed2121's Avatar
bboed2121 bboed2121 is offline
2002 Chevy TrailBlazer LTZ
Black 4.2L I6 4X4
Hi Folks. 2002 LTZ 170k miles. I started noticing some noise from the engine area. Definitely a worn-out type noise. I thought it may be the idler bearing or belt tension pulley (which ever is the proper description). I squirted some WD-40 on it and still had the noise. I listened around a bit and it sounds like it possibly could be under the front timing chain cover. Any way to tell for sure before I take the cover off and inspect? Anyone with this mileage ever have to replace the chain and gears or tensioner?
Thanks in advance
Old 09-19-2011, 02:39 PM
2003 GMC Envoy SLT
There is a tensioner pulley and an idler pulley. Did you check both?
Old 09-21-2011, 02:31 PM
tricguy007's Avatar
tricguy007 tricguy007 is offline
2004 GMC Envoy SLE
Summit White 4.2L I6 4X4
take the acc. belt off and see if the noise is still there if the noise stops its in the belt area
Old 09-21-2011, 04:27 PM
Ralph_T's Avatar
Ralph_T Ralph_T is offline
2005 GMC Envoy SLE XL
Take off the belt and listen again. If the noise stops then change both idler and tensioner pulley's if you can not remember them being changed at all.
