Towing Capacity - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 General Tech Q&A > Towing
Towing Towing with your TrailVoy
Old 10-07-2011, 04:38 PM
billy_rud10 billy_rud10 is offline
2007 GMC Envoy SLT
Towing Capacity
Just curious if someone could help me calculate my towing capacity.
GVWR: 5750lbs
GAWR FRT: 2960lbs
GAWR RR: 3200lbs
GCWR: 10,500lbs(thats what the manual says)
Hitch: 5500lbs
Hitch with WDH: 7200lbs
For towing I will be using a WDH to assist with the soft suspension the envoy has.
Old 10-07-2011, 05:31 PM
Me007gold Me007gold is offline
Hitch: 5500lbs
Old 10-07-2011, 05:56 PM
bartonmd's Avatar
bartonmd bartonmd is offline
Basic Vendor- Skid Plates
2007 Chevy TrailBlazer LS
Originally Posted by Me007gold View Post
Hitch: 5500lbs
That's what the hitch is rated to tow, not what the vehicle is rated to tow...
I don't think there's an I6 model that's rated to tow more than 6k... The V8 SWB models are rated up to 6800, IIRC, depending on ratio...
I thought it was in the manual? Gear ratio vs. wheelbase vs. 2/4WD vs. engine gives you the tow rating...
Mike
The GB ended, but PM me if you want one!
GB also ended, but PM me if you want these!
Old 10-07-2011, 06:30 PM
delete
Old 10-08-2011, 04:08 AM
de3jr88's Avatar
de3jr88 de3jr88 is offline
2003 GMC Envoy SLT
The I6 2wd with 4.10 gear ratio is capable of 6300, I6 4wd with 4.10 can tow 6100. The towing capacity reduces by about 500lbs for each step down in gear ratio to 3.73 and 3.42.
And yes, your hitch capacities and vehicle capacities are almost never the same. Always go by the lower capacity and you will not only be safe, but legal as well.
Old 10-08-2011, 11:05 AM
bartonmd's Avatar
Thanks! I couldn't remember off the top of my head, so I went to the manuals section of this website (or could have gone to my owners manual, like the OP should have), and copied and pasted the pages from the manual into 1 JPG file, uploaded it to my Picasa page, then posted here:
Old 10-08-2011, 09:10 PM
jkust jkust is offline
Senior Member
2007 Buick Rainier
Imperial Blue Metallic 5.3L V8 AWD
Doesn't seem logical that the SS with 4.10 tows the same as the 5.3 with 3.73. Wonder which part is limiting the capacity.
5.3L, 3.73, Nav, XM, Entertaiment system, Heated leather, Moon roof, Chrome edge running boards, Chrome rims
Old 10-08-2011, 11:12 PM
bartonmd's Avatar
The effective load goes up with more power applied... The SS has ~100 more HP than the 5.3, and will be harder on parts...
Mike
Old 11-06-2011, 07:56 PM
Duaner Duaner is offline
2002 Chevy TrailBlazer LS
just wondering what is the best way to find out what the axle ratio is, unfortunately I do not have the original documents for my vehicle.
Old 11-06-2011, 07:59 PM
Under the resources tab at the top of the page is a link for RPO codes, those codes will correspond with a decal in your glove box. One of those codes will tell you what ratio you have
