2003 Trailblazer Remote Start Help Please - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 10-26-2011, 08:45 PM
frankbev frankbev is offline
2002 Chevy TrailBlazer LS
I have a 2003 Trailblazer that I installed a Avital 5303 in it with the DEI 455G and a Bulldog key elem. When I try to remote start it the truck trys to start but wont... I checked the remote start and it is turning all the igintions and feeding power to the Start wire but wont start. It works sometimes when I turn the key to on. Then works for a bit and stops working again. Need help what this could be. Thanks in advance
Old 10-26-2011, 09:04 PM
MAY03LT's Avatar
MAY03LT MAY03LT is offline
TrailVoy Guru
2003 Chevrolet TrailBlazer LT
Scratchy Black 4.2L I6 4X4
When you first activate the remote start, and the dash lights up, can you see the security light blink? It might take a couple tries.
The 455G will disable the factory alarm for alarm/keyless but not passlock for remote start.
The yellow wire (start) only sends a 12v signal to the pcm. The pcm grounds the starter relay to start the engine. If the pcm does not get a valid passlock signal, the pcm will not ground the starter relay and the engine will not crank.
Old 10-29-2011, 08:54 PM
Thank You for the advice.. I have not been able to check been working too much. Now with the snow in Connecticut I will have to fix this soon. I will be installing a DEI 556LW and getting rid of the bulldog unit. Will keep you posted to if it works
Old 10-29-2011, 09:29 PM
MAY03LT's Avatar
TrailVoy Guru
The 556 is an antique! Not saying there's anything wrong with it, use what you gotta use, but most of 02-04 guys use the xpresskit gmdlbp. Passlock messages are sent via the vehicles data bus (over a single wire). It is much easier to install and program. It also does the door locks, so you wouldn't need the 455 either.
Old 03-09-2012, 07:11 AM
inazar2 inazar2 is offline
2003 Chevy TrailBlazer LT
Black 4.2L I6 4X4
Trailblazer 2003 does'nt start with remote.
i just brought used Trailblazer 2003 LT. When i pressed lock button twice on remote it take ignition and it started but with 2 seconds is stop and its trying again start but engie stop with 2 or 3 seconds. There is no engie service soon light. Any budy help for this issue.
Old 03-09-2012, 08:45 AM
Loverotties Loverotties is offline
2002 Chevy TrailBlazer LTZ
Mine acted up like that when the battery was weak,I charged the battery and disconnect it for 20 min and reconnected it and works fine now.
Old 03-09-2012, 08:54 AM
mika's Avatar
mika mika is offline
2002 Chevy TrailBlazer LT EXT
Are you sure you have all the wires n the right place?? Do you have the relays to bypass the PassLock II system that prevents your car from starting? If I were you and getting fed up, pay the $75.00 to $100.00 to have it fixed by a tech, A few hours and everything works and you will not have sweared once.
Marc Mc 2.5" lift, 1.5" wheel spacers and BIGGER tires to come
Old 12-18-2014, 07:22 AM
bmficc bmficc is offline
i have a 2003 ltz trailblazer with i believe to be a factory installed remote starter, how do i use the key fob to activate it?
Old 12-19-2014, 01:00 PM
pman_64 pman_64 is offline
2004 Chevy TrailBlazer LT
Black 4.2L I6 AWD
To my knowledge, GM never offered factory installed remote starters.
