[SOLVED] P0411 Code - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 10-27-2011, 08:58 AM
woody79 woody79 is offline
2008 Chevy TrailBlazer LS
Unhappy P0411 Code
Hi there ...
I hope someone can help me with a little issue I am having. I have a check engine light, which, when read comes back still as P0411 (Air Injection System Fault). Thinks I have done so far:
* Replaced the air check valve (there was a loud whining sound on a cold start which has now gone away after the valve replacement). The old valve was caked in carbon once I opened it up.
* Replaced the relay
* The air pump has a strong current of air coming out of the hose and the suction is good on the pump
* All of this was done last Saturday, so I have started the engine cold a number of times.
I have driven over 100 miles since replacing the valve. I thought that driving 100 miles would clear this code? I will swing by Advance Auto tonight and have the code re-read and see if they can clear it.
I need to try and figure this out asap as I have to get the truck inspected this month
side note: The truck is a 2008 LS and has 75,000 miles on it. This is the first issue I have ever had with this truck. Well apart from having to replace the side mirror last year.
Is there something I am missing, or not doing to correct to get rid of this code?
Thanks for any help in advance,
- Woody.
Old 10-27-2011, 09:12 AM
shorty's Avatar
shorty shorty is offline
2005 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
sent you a pm
I'm not a mechanic, but i did stay at a holiday inn express last night !
Old 10-27-2011, 11:46 AM
the roadie's Avatar
Usually takes three "driving cycles" to clear the light. Start, drive around until warmed up, stop for long enough to get cold again. Or a code reader should be able to clear it.
Might be a sluggish O2 sensor if the code was P0410, but the newer system P0411 error isn't discussed in my 2004 shop manual.
Old 10-27-2011, 05:30 PM
Jamie218's Avatar
Jamie218 Jamie218 is offline
2008 Chevy TrailBlazer LT
Black 4.2L I6 2WD
Originally Posted by woody79 View Post
Hi there ...
- Woody.
I have the same issue. I did the change out of the valve, relay also. my pump is strong and working. I even made sure the hoses were clear. Mine is a 2008 LT 6 cyl. with 60,000 on it. I have had it cleared out 3 times and it is the only thing that is showing up on the scanner. I am getting and I am almost short of yanking the led that lights up the Check Engine Light, so I don't have to look at it.
Anybody have a fix to this, please, I will take all actions to try and correct it. I don't wanna take it to the Stealership, cuz they will charge an arm and leg to fix it since it is not under warranty anymore.
Old 10-27-2011, 05:35 PM
Lightbulb
Question ..... Could the pump be bad and throw the code, but still act like it running strong (strong current coming out and pulling air into he pump strong)?
I will get the code cleared this evening (either that or disconnect the battery for 20 minutes or so). I need to get the light out before Saturday as I need to get it inspected.
Old 10-27-2011, 05:39 PM
Could just use some black electrical tape ...
"... look see there is no check engine light on, Mr mechanic who is trying to pass my truck for inspection... I have no clue what you are talking about"
Old 10-27-2011, 05:41 PM
Thanks Roadie .... I'll get the code cleared tonight and see what happens.
Old 10-28-2011, 08:50 AM
Talking
so..... update time...
I disconnected the battery last night for 30 minutes and then started her up. Check engine light is now gone. I drove around a little last night without an issue. Started it this cold and frosty morning and it is still out. MY wife drove the truck 30 miles to work and it still hasn't come back on.
Crossing my fingers now, hoping it stays this way.
Thanks for everyone's help. As always this forum has saved the day again. Its such a valuable tool for anyone who wants to save some $$$ and get some solid answers to issues they have.
- woody.
Old 10-28-2011, 09:05 AM
shorty's Avatar
Thumbs up
Good news, your good to go. Did mine a month ago all is good
For everyone out there doing this job make sure you disconnect your battery
so computer can reset
Old 10-28-2011, 09:14 AM
Talking
Originally Posted by shorty View Post
G
Someone forgot to do that
But hey they say you learn by your mistakes right? well I should be able to write a book
Thanks again shorty for all the help
- woody
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
