how to tow a 4x4 trailblazer? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > The 02-09 "How-To" and DIY Section
The 02-09 "How-To" and DIY Section Threads on Do-It-Yourself and How-To goes here.
Old 10-30-2011, 01:32 PM
hecsz28 hecsz28 is offline
2005 Chevy TrailBlazer LS EXT
Hi. My 05 Ext TB's tranny went out in Aneheim, Ca.
I have to tow it back to Phoenix, AZ, about 350 miles. Is there anything special I need to do before I can tow it?
I will be driving an 07 Avalanche and was thinking of renting a 2 wheel tow dolly. If that can't be done then I will have to rent a trailer big enough to fit the whole truck.
If I use the dolly, is it best to have the rear wheels on the ground? Any info is appreciated, Thanks.
Old 10-30-2011, 01:38 PM
ylab's Avatar
ylab ylab is offline
2002 GMC Envoy SLT
Summit White 4.2L I6 4X4
Just to make sure you don't damage anything further, put the selector into neutral.....its just past the 4Lo setting, no marking, you turn the knob to it and a red 'N' will illuminate. That will disconnect the rear axle from the transfer case and transmission. Loads easier than crawling under and disconnecting the drive-shaft. - I don't recall, but it might even be possible to flat tow it in 'Neutral', the manual may even mention it.
bartonmd's Avatar
bartonmd bartonmd is offline
Basic Vendor- Skid Plates
2007 Chevy TrailBlazer LS
Well, you're lucky that it's a 4WD TB, not a 2WD or AWD... A trailer is always best, but if you're going to use a dolly, you can put the transfer case in Neutral, and put the rear wheels on the ground... The procedure for getting the T-case in Neutral is in the owners manual, but I think you put it in 4LO or something, then rotate the switch farther over to the right and hold it there for a few seconds, until the "N" light stays on... Anyway, it's in the manual...
Mike
The GB ended, but PM me if you want one!
GB also ended, but PM me if you want these!
Old 10-30-2011, 01:41 PM
bartonmd's Avatar
Gah! beaten by mere seconds!
Mike
Old 10-30-2011, 02:31 PM
the roadie's Avatar
Originally Posted by ylab View Post
... it might even be possible to flat tow it in 'Neutral', the manual may even mention it.
The manual mentions it, but that's for folks who want to go to the expense of adding a tow bracket to the vehicle, like full-time RV'ers who tow behind their motor home. And the RV'ers also add an expensive remote control braking gadget to control the towed vehicles brakes, since in many jurisdictions you need brakes on towed items over a certain weight.
Let's see...... yep. CA and AZ both have 3000 pound limits.
Abandon the idea of an interstate flat or 2WD tow. Rent a trailer, and tell the rental agency you're going to put a Honda Civic on the trailer, unless you do the math and the trailer and tow vehicle are BOTH capable of your gross load. Anonymously calling UHaul may be a good first step.
Old 10-30-2011, 04:57 PM
Thanks for all the good info. I will see what it costs to rent a dolly/trailer, if they are close i will probably get the trailer.
If for some reason it wont go into neutral, can i disconnect the rear driveshaft from where it connects to the rear differential and hold it off to the side with a strap or something?
Old 10-30-2011, 05:22 PM
the roadie's Avatar
Four small bolts and the rear u-joint comes apart. Then you can slide the driveshaft rearwards to disengage it from the splined slipjoint at the end of the transfer case.
Old 10-30-2011, 09:53 PM
02blkws6 02blkws6 is offline
2004 Chevy TrailBlazer LT
Dark Gray Metallic 4.2L I6 2WD
Dolly is ok for short distances. Trailer for anything more than 100mi. This is just my personal preference and what I go by. Put it on a trailer and you won't be wearing any parts on the trailblazer.
Old 10-30-2011, 11:25 PM
kglover720's Avatar
kglover720 kglover720 is offline
2004 GMC Envoy SLE XL
Using a trailer will make your Avalanche more manly.
I can't wait until tomorrow because I get better looking every day.
Old 11-01-2011, 01:34 AM
ElAviator72 ElAviator72 is offline
Originally Posted by the roadie View Post
Rent a trailer.
How does U-Haul manage to get the darn things to weigh 2,200 lbs. empty? Lots of extra weight to be hauling around, especially when you're planning on putting a 4,600 lb. GMT360 on it I know, I know, I've seen the pics of the epic Roadiemobile tow back from Colorado...
