Code P0410, o2 Sensors, and Secondary Air Pump - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 11-19-2011, 02:14 PM
ChevyBell's Avatar
ChevyBell ChevyBell is offline
2005 Chevy TrailBlazer LS
Summit White 4.2L I6 4X4
I have a couple of question and brand new to this site. However please no one get mad at me for maybe asking a question that maybe on here. I am a female that is needing help.
I have a 2005 Chevy Trailblazer throwing a code P0410. I know that is the Secondary Air Pump Injection. Last week I had that changed to a brand new one. Couldn't figure out why the light wouldn't go off so I had someone turn it off. The light came on after 10 miles. Reading I learned that it could be a o2 sensor. Changing both upper and lower sensors shortly. However, with me changing the pump and sensors, am I needing to change something else also to get the pretty little light to go off my dash. Any and all help would be grateful cause I love my truck just hate the light.
Old 11-19-2011, 03:02 PM
2003 GMC Envoy SLT
Welcome
Did you have the light turned Off again? The light takes a few heat/cool cycles to go OFF by itself.
Are you sure the light is the same code as before?
Did you use an AC Delco O2 sensor? These trucks don't always like the Bosch O2 sensor.
Old 11-19-2011, 03:05 PM
ChevyBell's Avatar
I didnt have the light turned off again after it came back on after 10 miles. I drive my truck everyday. Yes I have the code checked again at work. We are in the middle of changing the o2 sensors right now. The back on is a Bosch and the front one is a NTK
Old 11-19-2011, 05:08 PM
the roadie's Avatar
Did anyone troubleshoot the system, or are you just changing parts by guessing?
Read this thread:
http://forums.trailvoy.com/showthread.php?t=45668
There are the pump and a relay underneath the truck. A relay and fuse in the front fuse block, a solenoid valve on the exhaust manifold, and the upstream (exhaust manifold before the cat) O2 sensor involved in the system
Only use AC Delco for the upstream O2 sensor.
The right way to begin to troubleshoot the system is to remove the hose from the pump at the solenoid valve on the exhaust manifold. On a cold start, listen for exhaust noises from the solenoid valve, and feel the turbine air pump blow air out the hose. If either one of those things doesn't happen, you'll have a clue which way to proceed.
Guessing only will end up costing you money. Makes us sad to hear that.
Old 11-19-2011, 05:36 PM
ChevyBell's Avatar
We have done that and the pump is working. You can hear it when the vehicle starts. No water was found and the hoses are good. So the sensor were next. We are able to change the downstream but the upper is giving us problems. I can' get it out. Rented a tool for the sensor and it keeps slipping. IDK what to do now
Old 11-19-2011, 06:07 PM
Ralph_T's Avatar
Ralph_T Ralph_T is offline
2005 GMC Envoy SLE XL
The O2 sockets don't seem to work very well at times. You need a pipe wrench to take it out.
Old 11-19-2011, 06:45 PM
woody79 woody79 is offline
2008 Chevy TrailBlazer LS
Air Pump
Just my ... I recently had this issue on my 08 TB. Mine was a P0041 (?) code. I replaced the valve on the manifold (as that was caked in carbon and not opening correctly).
I found that on a cold start when disconnecting the hose on the valve I felt a strong current of air, so I thought the pump was ok. It actually turned out that my pump ran on a cold start, but apparently not for the correct amount of time required by the PCM. After replacing the pump and the valve my light went off.
But as Roadie said there is a lot involved in the SAIS. I would defiantly agree with reading the thread he posted, I found it very helpful.
Anyway as I said that's just my
Edit: I replaced the valve first, cleared the code and it came back on, after that I replaced the pump.
Old 11-19-2011, 07:31 PM
Chickenhawk's Avatar
Chickenhawk Chickenhawk is offline
Senior Member
2004 Chevy TrailBlazer LT
You can cut the wire and use a regular deep socket for removing the front sensor.
But for future reference, trouble codes only indicate symptoms, they don't indicate causes of problems. You have probably wasted a lot of time and money unnecessarily replacing your oxygen sensors. You may have even caused yourself future grief by not using AC Delco oxygen sensors.
The front sensor should be replaced every 100,000 miles or they may seize to the manifold. The back sensor should last the life of the vehicle.
Randomly throwing parts at a problem is not the way to go. If someone is advising you to do this, it is time to find a new mechanic. Someone who knows what they are doing and has access to a scan tool with a live readout function can tell you in five seconds if the front oxygen sensor is working properly or not. That five seconds can save you hundreds of dollars of parts and labour. Plus, the back sensor almost never goes bad, and contributes nothing to the performance of the truck; it is only there to verify the condition of the cat converter.
If it was me, I would get an AC Delco sensor for the front. Why take a chance on something else when we know AC Delco are the only parts that work problem-free for owners 100% of the time, unlike other brands that are hit-and-miss. (The same goes for spark plugs. AC Delco 41-103 plugs are the ONLY ones that should be installed in our trucks.)
A good scan tool and someone who knows how to read it can save you a lot of time and money. (And we are not talking about some overpriced cheap junk code reader that is sold on late-night TV; we are talking a PROPER scan tool with a live-readout function.)
Hopefully, with the help of this forum and the great folks in here, you can solve your problems. Welcome and let us know what happens.
Old 11-08-2012, 05:32 PM
Snuke Snuke is offline
2005 Chevy TrailBlazer LT
Black Granite Metallic 4.2L I6 4X4
I had the annoying engine light and also had a code P0410, so I took my 2005 TB to the local Chevy dealer. They found it to be a failed relay on the secondary air pump. Pretty cheap fix, and took care of the problem. The P0410 code that you get, points you in the right area, but it takes someone who knows what they are doing to narrow it down to the real problem.
I recommend that you just take it to a professional and let them figure it out so you aren't chasing your tail and replacing parts that aren't the problem.
Old 11-12-2012, 04:09 PM
OK an update ................ the relay did not fix the problem, so it is going back in for service again to hopefully really fix the issue this time.
I will post back with results once it is determined if they really fixed it on their second attempt.
