Speed-dependent noise started yesterday, sounds like heavy tread road noise - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-09 SS Engine and Drivetrain > AWD Drivetrain
AWD Drivetrain AWD repairs & problems
Old 01-11-2012, 10:55 AM
jwthompson21's Avatar
jwthompson21 jwthompson21 is offline
2006 Chevy TrailBlazer SS (LT)
Superior Blue Metallic 6.0L LS2 V8 AWD
I just noticed this yesterday, never heard it before. Could it be a wheel bearing? Sounds like it is coming from the front of the truck. Mine is 2006 AWD with about 68,000 miles. I just changed front diff fluid about 2 months ago.
Thanks
Old 01-11-2012, 11:25 AM
Foglight Foglight is offline
2003 GMC Envoy SLT
Black 4.2L I6 4X4
Does it seem to load up in a corner or it it constant ?
Old 01-11-2012, 04:23 PM
I will have to pay attention for changes when I take a corner. I know it had to have just started yesterday, because it makes a harmonic sound against the sound of the engine, kind of like two people singing slightly out of pitch with each other.
Old 01-20-2012, 04:28 PM
Confirmed bearing noise
Yes, indeed, it is one of the front wheel bearings. Although I don't notice the noise increase around corners, I do know that my description fits perfectly with several other AWD owners, including the 'offroad tire sound'. So I will be getting the ol' jack out to confirm which wheel (or maybe both)?
Old 01-27-2012, 07:21 AM
06 Silver TBSS 06 Silver TBSS is offline
Silverstone Metallic 6.0L LS2 V8 AWD
06 awd front end noise
How Do you know its the front wheel bearing? I have an 06 with 49,000 miles and that same noise just appeared. Just wondering how you figured that out.
Old 01-27-2012, 09:24 AM
I am not 100% on my conclusion. But after researching the issue I believe that has to be the answer. A lot of owners of the AWD report the exact same noise and resolved with bearing replacement. Also, the noise started with mine immediately after the first salting of the roads for snow. So that is why I am very confident in my presumption. I will report back after I do my inspection.
Old 01-29-2012, 01:18 AM
oops, unsolved!
Okay, jacked up the front end and rotated both wheels by hand carefully listening for any noise. No luck, they are both sounding fine. I am now leaning toward this being the passenger side intermediate shaft assembly. I made an order for all the bearings, washers, and seals to service this and mod it to lubricate with gear oil.
Old 01-23-2013, 04:59 PM
Sentinel Sentinel is offline
2006 Chevy TrailBlazer SS (LS)
Summit White 6.0L LS2 V8 AWD
I had a similar noise I think it was the front diff being low on fluid
White SS AWD
Old 01-29-2013, 12:09 AM
kennethmull's Avatar
kennethmull kennethmull is offline
Black 6.0L LS2 V8 AWD
I had the exact tire/road noise. Replaced tires and had the pros inspect the front end. Pros advised it was the tires. Decided to just replace both front bearing assembly. Problem fixed. Of course, $1500 later though for a $100 fix. By the way, noise started at 50000 miles
You may not post new threads
You may not post replies
