Front Bumper Is Loose. Sides Came Off The Support. Easy Fix? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-09 SS Appearance > Exterior
Exterior Exterior repairs/modifications
Old 01-11-2012, 08:08 PM
gearheadvr4 gearheadvr4 is offline
2006 Chevy TrailBlazer SS (1SS)
Black 6.0L LS2 V8 2WD
Recently my bumper became unglued. I used the very high-strength plastic glue from Autozone and it lasted for a few months but came off again.
What is the best way to reattach the bumper to the support?
Old 01-11-2012, 08:17 PM
Filter Filter is offline
2006 Chevy TrailBlazer LS
I'd also like to know. Is this a common problem on factory or aftermarket bumpers? Or both?
Old 01-17-2012, 04:25 PM
Anyone else have this issue. Ideas?
Old 01-17-2012, 09:25 PM
lint's Avatar
lint lint is offline
Senior Member
2004 Chevy TrailBlazer LT
I had a kick plate crack and used Permatex Plastic Tank Repair Kit ,worked great ,It has a fiberglass mesh with it,been on for 2 years and hasn't cracked. You could try construction grade liquid nails if there is big enough area to glue.. Make sure you clean it well.
http://shop.advanceautoparts.com/web...7CGRP2050_____
Not sure if thats the one with the mesh .but I think it is.
Old 01-18-2012, 03:41 PM
LMMJ's Avatar
LMMJ LMMJ is offline
2002 Chevy TrailBlazer LS
Indi-GO Blue Metallic 4.2L I6 4X4
mine broke loose when my little brother tapped a parking block (truck is lowered and he pulled up too far)
Luis
Old 05-06-2012, 04:38 PM
Peco's Avatar
Peco Peco is offline
2008 Chevy TrailBlazer SS (3SS)
Black 6.0L LS2 V8 AWD
I just purchased a SS and I have the same problem, I'm going to try some JB Weld.
Old 06-03-2012, 05:02 AM
bullguy's Avatar
bullguy bullguy is offline
2007 Chevy TrailBlazer LT
Imperial Blue Metallic 4.2L I6 2WD
Silicon is the best solution.it has a good adhesion to the bumper, but you have hold it intact after applying atleast for 2 hours
The roots of true achievment lie in the will to become the best you can become
Old 09-12-2012, 06:55 PM
Govoryat Govoryat is offline
Philadephia, PA Philadephia, PA Philadephia, PA
Philadephia, PA 5.3L V8 2WD
Thank you for*your post!*Very interesting!
Old 11-21-2012, 09:37 AM
alarm15613 alarm15613 is offline
2008 Chevy TrailBlazer LS
Had the same problem on my 2008 Trailblazer LT. Did some VERY mild off-roading and the clip snapped and the bumper cover sprung out about an inch. I'm gonna give the Permatex a try. BTW- I also had my engine manifold crack at 50K miles. Paid $500 to have it replaced then found out Chevy will cover it for 10 Years or 120K miles for any owner. They certainly don't build em for 4 wheeling like they used to.
Old 11-23-2012, 07:32 AM
impynyc's Avatar
impynyc impynyc is offline
I had the same problem. The body shop use a plastic weld/ glue from Lord products called 143. Or somthing like that.
