Oil Pressure Sensor location - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 5.3L V8 Engine and Drivetrain > OEM Issues
Old 01-28-2012, 12:09 PM
kybreos kybreos is offline
2006 Chevy TrailBlazer LT EXT
Silverstone Metallic 5.3L V8 2WD
Hi, does anyone have a picture of where the oil pressure sensor is on a 2006 5.3l V8 trailblazer?
Old 01-28-2012, 01:43 PM
Well i was able to find it on google, and i replaced the part. The oil pressure reads normal now, however i need to figure out how to reset the check engine light.
Old 01-28-2012, 01:57 PM
cbwilsha cbwilsha is offline
2003 GMC Envoy SLT
Pewter Metallic 4.2L I6 2WD
It will turn itself off if no further problems are detected in the next few ignition cycles.
C.B.
Old 01-28-2012, 04:25 PM
Thx, i reset it myself by unhooking the negative terminal on the battery then waiting 10mins before turning it back on. Now to soak my knuckles in some ice lol.
Old 05-01-2012, 02:00 PM
mvillani mvillani is offline
2006 GMC Yukon
Summit White 5.3L V8 4X4
Hello all. I just replaced the oil pressure sensor on my wife's 2006 Yukon (5.3 engine). I was able to replace with only removing the plastic intake cover and the air intake (from air cleaner to throttle body). This required loosening three 5/16 screws (one on intake cover and two clamps on air intake) and four screws (air cleaner cover). These were removed to ensure they weren't cracked as I laid across engine to reach back of engine on the drivers side (right side) to remove the sensor. Location is directly under firewall before back of engine meets the transmission. I used a 3/4" drive, two 6" 3/4" extensions, swivel, and a Autozone Oil pressure sensor socket #25254 to remove the sensor. I will try and add pictures for location and to show what I removed. Took 15min max. Hopefully this will help!
Pictures as promised:
Plastic intake cover removed (one 5/16 bolt):
Air intake (from air cleaner to throttle body - two 5/16 clamp screws and 4 air cleaner screws:
Oil sensor socket from Autozone:
Driver, extensions, swivel, and socket:
Location of sensor when laying on top of engine towards windshield:
Another view:
Old 11-21-2013, 05:47 PM
Povozmojno Povozmojno is offline
qwerty qwerty qwerty
qwerty 5.3L V8 4X4
Its really great posts.
