| General If it doesn't fit in any other forum |
02-26-2012, 07:50 PM
2006 Chevy TrailBlazer LS Sand Beige Metallic 4.2L I6 4X4
p0171 system too lean
What does the error code p0171 system too lean mean? How do we fix it? Its on a 2006 trailblazer
02-27-2012, 07:26 PM
2005 Chevy TrailBlazer LS Summit White 4.2L I6 2WD
could be bad gas, or a fuel injector
02-27-2012, 07:28 PM
2006 GMC Envoy SLE Cranberry Red Metallic 4.2L I6 4X4
a dirty MAF , loose intake manifold bolts , or a bad o2 sensor
Keith Northeast Chapter MA Rep K&N 63 Series, 6000k Hid lows and fogs, Magnaflow Cat -Back, 20's, G80
02-27-2012, 08:34 PM
2006 Chevy TrailBlazer LS EXT Silverstone Metallic 4.2L I6 4X4
I've got the same code popping up on my 2006 TB EXT. I was leaning towards an O2 sensor, but I'm going to try cleaning the MAF sensor and throttle body this weekend and see if that helps anything before I start throwing parts at it.
02-27-2012, 10:13 PM
It happens on almost every tank of gas around three quarters of a tank stays on for around 60 miles or so and usually when I'm sitting somewhere idling. I have tried getting gas somewhere else too.
07-25-2012, 07:38 PM
2003 GMC Envoy SLT XL Sand Beige Metallic 4.2L I6 AWD
I'm getting the same code...smh....I have replaced the o2 sensor, cleaned the TB, replaced the intake manifold gaskets did fuel injection cleaning and replaced the spark plugs and one coil.... Don't know what else to do....any advice is greatly appreciated.
07-25-2012, 10:02 PM
I put in some sea foam and quit getting gas at Murphy's and it hasn't come back on since.
07-25-2012, 10:40 PM
Thanks for the info...i'm going to try it tomorrow and see...
10-18-2012, 11:44 PM
2006 Chevy TrailBlazer LT Silver Blue Metallic 4.2L I6 4X4
P0171
Ive had this code pop up a few times but i have a scanner and turn it off by erasing the code and it wont turn on for a while but since the first time on acceleration there is a hissing noise kind of like if there was a hose unplugged or something but checked everything and it all looks good i did clean the throttle body and the mass air flow sensor and the hissing is still there its getting anoying not sure what to do next can someone give me some ideas or has this happened to anyone?
2006 Trailblazer LT 4.2
01-05-2013, 04:25 AM
2006 Chevy TrailBlazer LT Sandstone Metallic 4.2L I6 4X4
Any answers please I have the same problem on mine, I replaced o2 sensors front and back, I also replaced the maf sensor, I checked for any leaks, and everything seems to look normal. I do not know what to do I am really tired of this car since I bought the car I have been having this problem. Can you repeat what did you do with the foam and how did you do it please...
| Sponsored Links |
You may not post new threads
You may not post replies
