Replaced stat is there a bleeder valve or hose for air bleed. - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 5.3L V8 Engine and Drivetrain > OEM Issues
Old 03-13-2012, 10:19 AM
chasmanz28's Avatar
chasmanz28 chasmanz28 is offline
2008 SAAB 9-7x
Summit White 5.3L V8 AWD
Is there a certain way to get the air out of the system on the 5.3, from what im reading on alldata it doesnt mention anything about bleeder valves or hoses? i dont want to overheat the engine thanks.
Old 03-13-2012, 11:03 AM
shorty's Avatar
shorty shorty is offline
2005 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
put your heater and fan on high, stick a funnel in radiator opening to keep coolant from spilling out, and the air will bubble out,as coolant goes down keep filling till full
I'm not a mechanic, but i did stay at a holiday inn express last night !
Old 03-13-2012, 06:53 PM
Wyle Wyle is offline
Summit White 4.2L I6 4X4
Don't know about the 5.3 V8, but the service manual says there is a coolant bleeder hose on the 4.2 I6.
Old 03-15-2012, 11:18 PM
Meltdown211's Avatar
Meltdown211 Meltdown211 is offline
2008 Chevy TrailBlazer SS (3SS)
Black Granite Metallic 6.0L LS2 V8 2WD
Just did mine yesterday...
Shorty is right, take the radiator cap off, start the truck and let it heat up. Watch the coolant rise and fall AND burp bubbles. It took mine about 30 minutes to get all the air out. When its "done" the fluid inside the radiator will typically swirl. if it continues to rise and fall, there's more air inside. No need for any bleeder valve, just some patience will fix it.
Rev it a few times to jostle the air out too.
Old 03-16-2012, 12:00 AM
chasmanz28's Avatar
2008 SAAB 9-7x
I figured it out, that along with taking off the small hose on top of the engine worked thanks.
Old 08-05-2013, 06:43 PM
Sportjunkee Sportjunkee is offline
2005 GMC Envoy SLT
2005 Envoy bleeder
Does the service manual state where the bleeder valve is located?
I just replaced the upper & lower hoses, thermostat & ECT sensor and now truck has idle going low and high and not constant.
thanks
