Rear Brake squeal - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > Brakes
Brakes Performance Brake Upgrades
Old 03-15-2012, 10:46 PM
tgrucelski tgrucelski is offline
2005 Chevy TrailBlazer LS EXT
Superior Blue Metallic 4.2L I6 AWD
Rear Brake squeal
Greetings all,
New Trailblazer owner, picked up an '05 EXT with 77k miles a couple of weeks ago. Dealer found worn brake pads when it came in on trade and put new pads on all the way around.
Problem is this: Left rear seems to squeal intermittently pedal applied or no pedal applied or sometimes sounds like a shoe dragging (E-Brake?)
I've jacked up the rear end and can't duplicate the noise rotating wheel by hand.
Most likely cause?
1.) Insufficient anti-squeal paste applied to back of pads?
2.) Or possible E-brake issue? Rotors were not replaced. (Note I had pulled E-brake handle out of habit at one point a couple of days after I took delivery and that seemed to make the problem worse. Seems the previous owner hadn't used it as only the left rear seemed to hold)
Any ideas greatly appreciated.
2005 Trailblazer EXT LS
