[SOLVED] p0300 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > The 02-09 "How-To" and DIY Section
The 02-09 "How-To" and DIY Section Threads on Do-It-Yourself and How-To goes here.
Old 03-24-2012, 06:33 PM
beaconbab beaconbab is offline
trailblazer Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
p0300
I have a 04 trailblazer and its running bad. I checked for codes and first the p0301 came on. Replaced the plug and switched coils to see if it might be the coil. And now the code reads p0300. I dont know what to do... any help?
Old 03-25-2012, 03:16 AM
Donwkk Donwkk is offline
2004 GMC Envoy SLE
Don't assume the computer is smarter than you - it is not - and don't let it confuse you.
The computer has no magic way of knowing which cylinder is misfiring - it looks at various sensors and makes a guess - the first time around it guessed it was #1 and now it is being a little more truthful and admitting it is not sure which one or more are the problem.
You knew enough to try changing a plug and swap coils so you obviously have some experience doing it yourself - let the computer guide you but trust your common sense and go by past experience.
When you removed that one plug what did your eyes tell you - did it look recent and healthy or old and crusty - if the latter you should replace them all with ACDelco 41-103 as a first step. The proper Delco's work - don't accept whatever brand the local auto store is pushing this week - other brands might work as well but why add another unknown.
Recheck the coils - The front and rear coils can be tricky to seat properly - putting them down into the holes less than straight can result in the plug boot spring and plug top not making a good connection.
If problem remains with new plugs and properly seated coils move on to the throttle body - do a search for throttle body cleaning and you will find many threads and how to's on how and why you may need to clean yours.
Take it step by step and you will resolve the issues.
Old 03-25-2012, 02:25 PM
Don,
First off Thank You Very Much for your insight!
Plugs were just changed before about a 1000 mile journey a month ago as it was idling a little rough and it cleared it right up. We used the Bosch Platinum plugs as we heard they were the best for that particular vehicle.
I noticed the vehicle low on transmission fluid and added some and it is probably a little above the full line and about that time it started missing. We then cleaned the air temperature sensor on the air cleaner hose which helped tremendously and actually replaced it with a new one and removed the Throttle Body and cleaned it.
We then bought a DTC retriever and it popped up with P0301....next was to pull the number 1 spark plug....which was a little oil fouled on the electrode tip.....and not only replaced it but also swapped the number 1 & 2 colis to see if it was the coil in hopes of P0302 coming up telling us it was the coil.
Then the number P0300 came up and threw us for a loop.......I guess with all that said would over filling the transmission have anything to do with this at all?
Thanks again for your time and knowledge as we do appreciate it along with anyone else that might be able to help us.
Have a Great Weekend!
Beaconbab
Old 09-06-2012, 02:10 PM
I6 05 blazer I6 05 blazer is offline
2005 Chevy TrailBlazer LT
Black 4.2L I6 2WD
P0300 check engine light was blinking on my '05 tb
P0300 FIXXED!! no scanner necessary. Ok so I went on Craigslist to find a mobile mechanic for 20$ to check my OBD CODE, Because autoparts places cannot rent out obd scanners anymore in cali by law. my car was stumbling on start up and misfiring bad to where the car kinda shook, First we Got a code of P0301 (#1 cylinder misfire) after running a minute it started showing random misfire P0300, so i changed all spark plugs with no luck. Still stumbling and rough idle and check engine light on, I swapped the #1 cylinder "direct ignition coil" with the #3 cylinder ignition coil and rechecked codes. Still showing random misfire P0300 (P0301 nor P0303 didn't show up for the party at all). So with car still running went down the line and started disconnecting each ignition coil wire and replacing it back on. if it ran worse after disconnection the wire i would know that the coil is working.... so when i got to the #3 coil and disconnected it there was "NO" change in the idle and there for i new it wasn't firing ... I didn't want to get to excited because i had 3 more to check, so i continued on, all showed signs that they were firing YAY!!! Recap: the only one that didn't make a difference in the idling of the car was the # 3 cylinder. by swapping the coils you can do the process of elimination and not even need a code reader. Aldo you can rule out whether it is fuel related or wire related. long shot but its the cheapest process of elimination. in the end i bought a $62 lifetime warranty ignition coil for the TB and 140k miles she has new plugs and runs smoother than ever.
P.S. I cleaned the carburetor prior to doing all of this as i had changed the batter literally the day this all happened, (cause i thought it was a bad battery, i think the coil was shorting out and drained the battery) I thought it was having trouble resetting the air flow sensor and i read when the computer resets (battery disconnect) that any carbon build up in the throttle body can cause it to not idle correctly. so do this before any repair in this order: Prayer 1st, Process of elimination 2nd, persistence, patience & politeness.
Old 03-08-2013, 04:15 PM
EnvoyFam EnvoyFam is offline
2002 GMC Envoy SLT XL
Sand Beige Metallic 4.2L I6 AWD
Coils Seated correctly?
I have an 02 Enovy XL with 151K on it. We recently went from low elevation living (0 - 1000 feet above sea level), to high altitude living (5000 - 12,000).
The first weekend the Enovy was in high altitude it started to throw a mis-fire code P0306. I unfortunately paid a shop to replace all the spark plugs and clean the fuel system. It still mis-fired.
I have replaced all the coils now too. I am still getting a mis-fire code P0300. The Auto tech said it could be the way the coils were set. I thought I placed them properly. How does a properly set coil look?
It felt like I lined them up right. the coil was setting with a slight gap before I used the screw to tighten them down.
Old 04-05-2013, 08:59 PM
KNBlazer's Avatar
KNBlazer KNBlazer is offline
Senior Member
2004 Chevy TrailBlazer LS EXT
Steel Gray Metallic 4.2L I6 2WD
The way I did my first spark plug swap was by using dielectric grease in the boots, I too got a misfire, so I took each of them off one at a time, and wouldn't you know it.. In one of the coils the grease was intact, seated it once more and problem was solved...
Old 11-21-2013, 04:53 PM
Povozmojno Povozmojno is offline
qwerty qwerty qwerty
qwerty 5.3L V8 4X4
This posts is*very*informative.*Thank you!
Old 11-05-2015, 10:42 AM
junkdealer2 junkdealer2 is offline
2005 GMC Envoy SLT
WRECKED 4.2L I6 2WD
P0300 continuing, argggg!
OK, Got a p0300 and went through these steps, checked intake manifold seals with wrench and spray, compression test(even and ok across the cylinders), leak down test( ok), cleaned throttle body(both sides, yuck!), replaced plugs with AC's, swapped coils each one back one with fresh grease!
WHAT AM I MISSING, ARRRRGGG!
Can anyone help?
Old 11-05-2015, 01:53 PM
Bill Reid Bill Reid is offline
2003 Chevy TrailBlazer LS
Indigo Blue Metallic 4.2L I6 2WD
I got a P0300 (no other codes) yesterday. I happen to have HP Tuners so I was able to hook it up and scan for misfires. For me it was #4 cylinder. I swapped coil packs between #3 and #4 cylinders and the misfires moved to #3 cylinder. Replaced the coil pack for #3 cylinder and all is good now. Weird I did not get a P0304 (or P0303) code. Not sure why computer did not throw a cylinder specific code because that is where all the misfires were coming from... nothing random like the P0300 code suggests.
Old 11-13-2015, 07:24 PM
2005 GMC Envoy SLT
WRECKED 4.2L I6 2WD
Well, fixed the P0300 code today. Had 2 bad coils and 1 bad boot so I replaced all 6 coils. Now whats next? LOL
