Front End Vibration? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 07-07-2012, 09:37 AM
Canz Canz is offline
2004 Chevy TrailBlazer LT EXT
Silver 4.2L I6 4X4
Hello, I have a 04 trailblazer with 130,000 miles on it. Last week I replaced my radiator and water pump and added a transmission cooler, because it has been running hot (over 210) itís been doing this for the past 3 summers and I have previously replaced the thermostat and fan clutch and itís still running hot. Think I will be trying one of those fan clutch bypasses in the near future and hope that helps.
But on to my bigger problem after I got done replacing my radiator and water pump I notice a vibration starting at about 3000rpm and ending at 4500rpm. and not sure what could be causing that. I donít think the fan clutch is misthread or anything like that because it went on very easy. I also noticed I am now leaking front differential fluid from the driverís side seal and possibly the rear seal. The front differential fluid was changed about a month ago in South Carolina while on a PA to Fl road trip at my father in-laws who is a Nissan mechanic. When he changed the fluid it was very Gray. He said the might be some wear in it, but I wasnít going to push the free labor further because he was already doing about $1000 of free work at his dealership.
What can I be expecting with this differential and could this be the cause of my vibration, and not an unbalanced pulley like I was thinking?
Old 07-07-2012, 09:45 AM
racer383s's Avatar
racer383s racer383s is offline
2006 Chevy TrailBlazer LS
Silver Blue Metallic 4.2L I6 2WD
At what road speeds are the you experiencing the vibration?
Eibach Lowering Springs-Flowmaster 70&SS Tip Spectre Air Filter-12" sub W/Amp-CAF MOD
Custom-Bilt Receiver Step-De-Racked
Old 07-07-2012, 09:51 AM
Silver 4.2L I6 4X4
It kinda does it at any speed as long is its in that rpm range.
Old 07-07-2012, 10:00 AM
ylab's Avatar
ylab ylab is offline
2002 GMC Envoy SLT
Summit White 4.2L I6 4X4
What about the transfer case fluid, was it changed and if so did you use Autotrac (or RP Synchromax) fluid? - The Transfer case can create a vibration or shake when the wrong fluid is installed, badly needs replacing or the level is low. Many mechanics try to use DEX3/6, which doesn't have the friction modifiers that the Autotrac spec calls for. W/o those friction modifiers, the clutch plates partially engage causing a vibration or shake.
I only mention it as you mentioned that you did change the axle fluids, figuring you may have also done the transfer case as well.
Old 07-07-2012, 11:57 AM
Silver 4.2L I6 4X4
The Transfer case fluid was changed as well with one that has the friction modifiers in it.
Old 07-09-2012, 12:35 PM
drkhead drkhead is offline
2007 GMC Envoy
Blue 4.2L I6 4X4
Motor mounts?
Tags
differential, radiator, vibration
