Where is the AC recharge port? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-08 SS General Tech Q&A > General
Old 07-10-2012, 10:53 PM
thawkshaw thawkshaw is offline
2004 Chevy TrailBlazer LT
Graystone Metallic 4.2L I6 AWD
I have a 2004 trailblazer with 4.2l and the AC goes in and out. I want to evacuate and recharge but can't find the low pressure port. I only see the one on the evaporator canister. Is that the correct one? If so my guage is way over into the danger area. I assume that might be the problem.
Old 07-10-2012, 11:20 PM
c good c good is offline
Senior Member
2002 GMC Envoy SLT
There is no such thing as an "evaporator canister" on this AC system. On this vehicle, it is an "accumulator". The AC port on the accumulator is the Low Pressure (LP)connection to the system. The other access port is the High Side port and is located under the shroud on top of the radiator/condenser area in the left front of the engine compartment. HTH c good
Old 07-10-2012, 11:38 PM
Thanks,
I assume then that the overcharge is contributing to the AC going in and out. Maybe freezing up.
Old 07-11-2012, 12:39 AM
Senior Member
2002 GMC Envoy SLT
Is the Low Side Pressure high when the compressor is running? If so, it's overcharged if that's what you've been doing (adding more 134) Until you check both high and low side pressures while it's running (and compressor is engaged)you won't know for sure what the problem is. c good
Old 08-04-2012, 05:24 PM
kodeblue71 kodeblue71 is offline
2004 Chevy TrailBlazer LT EXT
Pewter Metallic 5.3L V8 4X4
I also was going to ask this question. So, after eading this thread, I understand that I have to hook the refill canister up to the port on the accumulator? If so, how do I do this? My kit I bought has a threaded hose. The port appears to be similiar to a quick connect style.
Old 08-04-2012, 08:05 PM
Senior Member
2002 GMC Envoy SLT
you must have bought the wrong kit (maybe for a Canadian System?) U.S.A. EPA laws mandate the quick connection type of fittings.
Old 08-04-2012, 11:56 PM
I am from Canada lol.
Old 11-11-2012, 11:08 AM
cowboyburns cowboyburns is offline
2002 GMC Envoy SLE
Summit White 4.2L I6 4X4
Where is the low pressure a/c port located on a 2002 GMC Envoy?
Old 11-11-2012, 09:45 PM
Senior Member
2002 GMC Envoy SLT
On the accumulator. It's the aluminum looking cylinder right by the passenger side firewall. HTH c good
Old 08-10-2014, 02:38 PM
julescole julescole is offline
Lurking Newbie
Thank you so very much...this is like the only place i've found the answer i was looking for. Who'd of thunk it would be so difficult to answer this question. THANKS AGAIN!!!!
Tags
air conditioner, recharge
