[SOLVED] P1514 and pending P0300 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > General TrailVoy Discussion > The "How-To" and DIY Section
The "How-To" and DIY Section Threads on Do-It-Yourself and How-To goes here.
Old 08-08-2012, 02:10 PM
chavez94 chavez94 is offline
2002 Chevy TrailBlazer LT EXT
Summit White 4.2L I6 2WD
Hi I'm new to this thread and I have a 02 trailblazer.recently i replaced the sparkplugs and now im getting a p1514 and a pending code p0300 i checked and cleand the throttle body and did not find any problems. I started my TB and it ran fine at idle but until i took it out engine light came on and reduce engine power and now it idles rough.any ideas on what to look for.
Old 08-08-2012, 03:32 PM
dtc p1514 and pending p0300 cont.
Ijust checked for any vacum leaks and no leaks were found.I just had the trailblazer running for a while and took it out to drive but has no power feels like it wants to die.rpms fluctuates between 5 and 6.
Old 08-08-2012, 09:31 PM
petevw's Avatar
petevw petevw is offline
2002 Chevy TrailBlazer LTZ
You removed the throttle body from the engine, cleaned BOTH sides, and had the battery disconnected for at least 35-40 minutes while doing the cleaning?
PCM4less,HID,DRL killer,cabin air filter,Mobil 1,K&N,LED's,193K+,
Old 08-25-2012, 08:06 AM
gcacace1289 gcacace1289 is offline
did you check the spacing on the spark plugs. if the spacing is off it can cause that, it happened to me.
2002 Chevrolet Trailblazer LT: 8000K HIDs, K&N CAI, DRL delete, Viper 5901, Cherry Bomb Custom Exhaust, Pioneer HU
Old 08-25-2012, 02:33 PM
petevw's Avatar
Huh???
OP hasn't responded to any questions/suggestions, but it says "solved" on the thread title. Real nice when posters come here looking for help, get help, fix their problem, but offer no thanks for it.
Old 12-11-2012, 07:46 PM
jake1's Avatar
jake1 jake1 is offline
2005 Chevy TrailBlazer LT
Black 4.2L I6 4X4
Unhappy Po306
I was wondering if anyone has new information regarding PO306, my MIL is constantly on now. In the past it would show up occasionally, perhaps once every couple of months. These are the things that I did, swapped coils, put in the AC Delco Iridium 41-103 spark plugs, new air filter, removed the throttle body and cleaned it on both sides and pulled the two PCM fuses and waited 30 minutes. At that time which was a few months ago everything was fine. Other than the code the TB has a slightly rough idle, but has great power for a vehicle with 174,000 mi.
Jake1
You may not post new threads
You may not post replies
