Rear hatch won't open - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 08-19-2012, 11:34 PM
slambam slambam is offline
2002 Chevy TrailBlazer LTZ
Red Jewel Tintcoat 5.3L V8 4X4
Hi all. I have an '02 Trailblazer, and just got home with some problems and was hoping somebody could give me some help. After leaving the grocery store I used my rear hatch. We got in and drove away. The dome lights didn't go off as I was driving, but I nothing ever came up on the dash saying that a door was open. Either way, we stopped and checked the doors and all were shut, except the rear hatch wouldn't open. Now that we're home, we have the same problems. Basically this is what I found weird...
- Rear hatch will not open
- Dome lights stay on (well, eventually go off)
- Buttons on the remote do not work
- When I turned the Trailblazer off, the radio stopped immediately (usually it stays on until a door opens)
ANY help would be appreciated, thanks!
Old 08-20-2012, 12:14 AM
szieziel szieziel is offline
2003 Chevy TrailBlazer LT EXT
probably the liftgate module ( besides controlling the locks of the lift gate and rear wiper, it also is the receiver for the fobs ) - start by checking the fuse for that, under rear seat #3 I believe
If everything is good there, check the wiring to the lift gate and the LGM; since you the remote is not working you will have to manually unlock the lift gate to open it. On the inside of the gate close to the bottom center is a round cover, when you pull that off you can move the lock arm.
Old 08-20-2012, 08:51 PM
Thanks szieziel. It was the wiring after I got the door open. All is back to normal, I appreciate it.
Old 08-22-2012, 12:50 AM
Red Kat Red Kat is offline
Pewter Metallic 4.2L I6 4X4
I have an issue like this and can't get the liftgate open! Even manually!! HELP!
Old 09-02-2012, 12:57 AM
Gevans17 Gevans17 is offline
2004 Chevy TrailBlazer LS
Dark Green Metallic 4.2L I6 2WD
cant open liftgate
Remove the plastic door liner, then manually unlock the rear hatch by lifting rod to rear latch..
Old 10-10-2012, 02:59 PM
Forcedtorque Forcedtorque is offline
2005 Chevy TrailBlazer LS
So, if my reading serves me right, my steps to correct this issue should be:
1. Check the fuse first
2. Manually unlock hatch through the hole
3. Check wiring at top
4. Replace the module if all else fails?
Where is the best place to get a replacement module as far as price and quality?
Selling, Buying, and Trading Trailblazer parts
Old 05-29-2015, 12:15 AM
Kaldor Kaldor is offline
2006 Chevy TrailBlazer LS EXT
Maroon 4.2L I6 4X4
I cant get past step 2 on mine. See my post in this forum:
h ttp://forums.trailvoy.com/showthread.php?t=153378 - remove the space, not enough posts to post a link....
Old 07-19-2015, 11:59 AM
davep1967 davep1967 is offline
Black 4.2L I6 AWD
My rear hatch won't open either, but my remote works, and the rear window opens.
