Scosche HD Amplifiers - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > Supporting Vendors > Scosche Industries
Scosche Industries Scosche Industries
Old 09-13-2012, 03:24 PM
ScoscheCarAudio ScoscheCarAudio is offline
Supporting Vendor
2002 Chevy TrailBlazer LS
Black 4.2L I6 2WD
HDA4002 - 400 Watts Max 2-Channel Amplifier
$99.95
HDA8004 - 800 Watts Max 4-Channel Amplifier
$129.95
If you're in the market to boost your audio system, check out Scosche HD amplifiers.
Scosche HD is designed for value without compromising sound quality or components. The HD amplifier line-up includes 2 amps. The 2-channel 400 watt amplifier (#HDA4002) boasts a 50 watts RMS x2 at 4 Ohms power output. The 4-channel 800 watt amplifier (#HDA8004) has 50 watts RMS x 4 at 4 Ohms power.
Features
-Thermal overload protection
-Sturdy Aluminum Side Panels
-RCA and high level inputs
-Brushed Aluminum Heatsink and Top Plate
-Dynamic bass boost
www.scosche.com
Old 02-03-2013, 06:07 PM
Supporting Vendor
Black 4.2L I6 2WD
Arriving Spring 2013!
Scosche HD 5-Channel Amp & HD Mono Amp
The two new HD amplifiers both feature Class-D topology, thermal overload and short circuit protection, variable crossovers, MOSFET switching power supplies, RCA and speaker level inputs, brushed aluminum heatsink and top plate and dynamic bass boost. In addition, the 5-channel amp and MONO amp have a bass knob included.
The new 5-channel amplifier (#HDA5CHANNEL) is the first all-digital amplifier under $300.00. It’s full-range channels boast 50 watts RMS x4 at 4 Ohms while the subwoofer channel outputs 250 watts RMS at 2ohms for full system power. It also features a separate front and rear input summing, remote bass control port, and selectable gain range.
The 500 watt mono block (#HDA1001) outputs 500 watts RMS x 1 at 2 Ohms and is a full-featured mono amp for under $200.00. It features a power protect indicator, speaker level input and remote bass control port.
Both amps will be available for purchase by Spring of 2013.
www.scosche.com
Old 02-04-2013, 06:08 PM
sidehopper sidehopper is offline
2003 GMC Envoy SLE
First thing, they look good. And they are priced right. Real good. Trying to pick one up soon.
Old 02-07-2013, 09:09 PM
Supporting Vendor
Black 4.2L I6 2WD
Thanks for checking our updates and the support! Let us know if you have any product questions or feedback on your purchase.
www.scosche.com
You may not post new threads
You may not post replies
