09-21-2012, 04:39 PM
2006 Chevy TrailBlazer LS EXT Indigo Blue Metallic 4.2L I6 4X4
Replacement Wheel Questions
I have a 2006 Trailblazer LS EXT with 6 lug 17" wheels. One of the wheels has recently cracked and no longer holds air. I was thinking I'd just get a set of 17" of craigslist or EBAY from a Silverado or Tahoe but I figured I better make sure GM actually did something really smart like make the bolt patters the same on ALL the 6 lug trucks.
So the question is, what OEM wheels can I buy that will fit my truck? Are the TB's unique or do they share common bolt patterns with other models and makes? I know I can use 8 lug Dodge wheels on my 3/4 ton Silverado, anything like that for the TB or am I better off hitting a boneyard? I 150, any channce they might actually fit?
09-21-2012, 04:57 PM
2003 Chevy TrailBlazer LT Silver Mist Metallic 4.2L I6 2WD
arent the sames
The TB bolt pattern is 6/127 (6 x5)
The wheel bolt pattern for the silverado is 6-139 (6x5.5)
09-22-2012, 06:02 AM
2002 Chevy TrailBlazer LTZ Majestic Red Metallic 4.2L I6 4X4
You'd need adapter to fit them.
11-04-2012, 10:22 PM
2006 Chevy TrailBlazer LT Superior Blue Metallic 4.2L I6 4X4
changing rim size
i have an 06 trailblazer lt 4wd and that year they did not make the 18*8 wheels, is it possible to put 08 or 09 18*8 chrome wheels on it? i have the 17*7 on it right now
11-05-2012, 12:20 AM
2005 Chevy TrailBlazer LS Summit White 4.2L I6 2WD
yes, the rims off of a newer TB will fit
11-10-2012, 05:48 PM
2004 Chevy TrailBlazer LS Midnight Blue Metallic 4.2L I6 AWD
I ran into the same problem with a cracked wheel so I figured what a perfect time to get new wheels. I bought wheel adapters so I can have a better selection but am stuck. I have an 04 Ls that had 16in wheels on it and the spacers I got are 1.5in thick so what back spacing am I looking for I have no idea?!?!?!?
11-12-2012, 03:57 AM
i found a set online for about 280 per wheel, so i can sell mine for about 200 a wheel this way the entire job will only be like 200 bucks in the long run, only problem is id have to get new tires now because the ones i have are only for 17x7 not 18x8
12-06-2012, 11:34 AM
2009 Isuzu TrailBlazer SS (1SS) Carbon Metallic 5.3L V8 4X4
Hi all there are many people are want to change the wheels but company is main problem and i think Yokohama this company are famous for wheels.
12-06-2012, 09:52 PM
Yokohama makes tires, not wheels...at least as far as I know.
I lucked out and picked up a set of 17" chrome wheels off an Envoy for $175 and they look great on the truck. Missing one hubcap, but thats an easy EBay fix.
Does anyone have a need for up to three of the old 17"s? They're perfectly good, no tires on em...a bit dirty but they'll clean up very nicely.
01-07-2013, 10:53 PM
2005 Chevy TrailBlazer LT Dark Gray Metallic 4.2L I6 4X4
Still have wheels
Hey if u still have the stock 17 your gettin rid of PM me and I hope we can set something up.
| Sponsored Links |
You may not post new threads
You may not post replies
