Blower Motor Resistor Module? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 10-02-2012, 03:47 PM
Mundane Mundane is offline
2003 Chevy TrailBlazer LT
Black 4.2L I6 AWD
Hi,
My '03 Trailblazer is having a malfunctioning HVAC system.
The blower motor only works intermittently and every great once in a while it will turn on by itself (with ALL switches turned OFF) and will continue to run AFTER ignition is turned off.
From what I gather, it is on an independent circuit, so turning the key off will have no effect whatsoever if the module is not acting correctly.
The fuse (#35, I believe) is good, so that just leaves the module underneath the dash, correct?
I am about to go to a pick your own part yard and see if I can get lucky, but want to make sure I am getting the right piece. What do ya'll think?
Thanks in advance!
Old 10-07-2012, 10:51 PM
panicked voy panicked voy is offline
2003 Chevy TrailBlazer LT EXT
same problem
my '03 had (still has) exact same problem and had the same symptoms prior to the fan dying. Just figured that it MAY be the resistor after checking the fan motor and finding its still good. New resistor will be in on Tuesday, will let you know if its the fix!
Old 10-09-2012, 02:08 PM
Black 4.2L I6 AWD
Thanks! Please be sure to post back with the results!
Old 10-15-2012, 12:05 PM
tsmaxwell64 tsmaxwell64 is offline
2002 GMC Envoy SLT
blower motor resister 2002 envoy
im haveing same problem on mine, going to get resitor today and replace it tomarow, i will keep you updated. ps its in a tight spot
Old 10-15-2012, 09:52 PM
Blower motor control module problem fixed!
Replaced blower control module part no. 89019351 and it seems to work. Only bummer is you have to cut the plug that feeds the module and splice wires from wiring harness to new module. Purchased part from dealer for $108, Napa wanted $124 & Advance Auto wanted $180! Good luck...
Old 10-16-2012, 01:02 AM
framedforlife framedforlife is offline
2003 GMC Envoy SLT
Just had mine done $300 from the dealership.
