Ticking Motor Noise - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 5.3L V8 Engine and Drivetrain > OEM Issues
Old 11-01-2012, 03:34 PM
hblackmon hblackmon is offline
2004 GMC Envoy SLT XL
Liquid Silver Metallic 5.3L V8 4X4
Ticking Motor Noise
While on a road trip last weekend, going down the interstate @ 75 mph and hear a ticking coming from the engine compartment, loud enough to be heard over the radio. It seems to be correspondant to the RPM, as when I let off the gass it slows down. I parked and listened, revved up, and heard it speeding up with the engine noise. Popped the hood and can hear it coming from the top of the engine, on the driver side, but behind the alternator/belts/etc, like possibly from the valve cover or spark plugs. We got to where we were going, the car sat and cooled for 4 hours, left, and was fine for the first 10-15 min, then when car was up to speed/heated up, it started again. I also have the infamous "oil pressure gauge drops when @ stop light but doesnt stall or anything", and not sure if this could be part of that? Checked the oil, levels are fine. 130k miles by the way.
Old 11-04-2012, 11:32 AM
JimW JimW is offline
2006 Chevy TrailBlazer LT
Liquid Silver Metallic 5.3L V8 AWD
What brand oil and filter.. ?
Weight of oil .. ?
How man miles on the oil and filter?
Old 11-04-2012, 12:46 PM
1badtrlblzr's Avatar
1badtrlblzr 1badtrlblzr is offline
2005 Chevy TrailBlazer LS
Summit White 4.2L I6 4X4
noise
Possibly the exhaust manifold they are known to crack its not a ticking noise but a pop and would change with engine rpm and loud enough to hear inside the cab with the radio on and is located on the left side of the engine not sure but just a thought
Old 11-05-2012, 12:12 PM
Weight of oil .. ?
Not sure the brand and weight. I have a service contract @ the dealer I got it from and they service it there. I do know it hit 4 over the weekend, so prob around 3800 when it started. I have an appt Wed to have it changed already.
I read something on that also. This is def more of a ticking, a higher pitch? i guess than a pop. I listened to one on YouTube also, and didnt sound like that. I'm going to check the spark plugs as well, as I did hear one similar that turned out to be a plug that had backed out a little. I'm gonna try some fuel injector cleaner @ next fill up also as I have read a mention (and heard from a mechanic friend) it could be a clogged injector.
Old 12-10-2012, 11:56 AM
FrizB FrizB is offline
2006 GMC Envoy Denali
Black 5.3L V8 4X4
This tick used to happen to me too. Almost always on the interstate and at high(er) speeds. The faster I went, the faster the tick.
I'm not sure if your issue is the same as mine, but I used to add a quart of oil and all was well. I since had to have my gasket and head cover replaced due to heavy oil consumption. All is well now. Do you also have excessive smoke blowing out the taipipe on a cold start?
You may not post new threads
You may not post replies
