[SOLVED] door handle - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > The 02-09 "How-To" and DIY Section
The 02-09 "How-To" and DIY Section Threads on Do-It-Yourself and How-To goes here.
Old 12-10-2012, 04:33 AM
TRAILBLAZINFOOL's Avatar
TRAILBLAZINFOOL TRAILBLAZINFOOL is offline
2002 Chevy TrailBlazer LS
door handle
does anyone know how to fix or replace a door handle? my right rear passenger side door handle is pulling out and is only attached at the top of the handle. can this be fixed or is it better to be replaced?
Just because you're mechanically inclined, doesn't make you a mechanic...get a second opinion!
Old 12-10-2012, 10:20 AM
ej_bennallie's Avatar
ej_bennallie ej_bennallie is offline
2005 GMC Envoy SLE
Tan/Gold 4.2L I6 4X4
Take out the door molding, Pull back the rubber insulator, with the window rolled up unbolt the two screws holding the door handle in place and detach the connectors to the door handle. Then push the handle outward. Then replace it when a new one, re-bolt the new one, add in the connectors, and put back the rubber insulator, the door molding. That should do it. I hope this helps.
Old 12-21-2012, 05:11 AM
Thanks for the help. Seems pretty straight forward and simple enough to do.
Problem I'm having now is I'm not 100% sure which handle I need to buy. I did a search on partsgeek.com and came up with several options. I have an 2002 tb LS and the door handles are black textured. The ones on partsgeek.com say smooth ready to paint finish which is not what I need. They also have 2 textured handles and the price on one is $8.23 and the other is$23. But both descriptions say right rear textured which is what I do need but I'm not sure which one to buy.
You may not post new threads
You may not post replies
