Surging and stalling at low rpm - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Air Induction
Air Induction Performance Air Intake/Air Induction Modifications
Old 12-11-2012, 06:13 PM
Zeker6 Zeker6 is offline
2003 Olds Bravada
Forest Green Metallic 4.2L I6 AWD
2003 Bravada.4.2 Finally got around to changing thermostat (0128 code) went fairly smooth other than looking for lower housing bolt that fell and hid, went in thru left wheel well after removing tire to remove and replace it.. Problem now is it surges and stalls at times at idle or low rpm surge, but code is out and none resetting. Could I have knocked something loose, was not a problem before thermostat replacement, and of course you need to unhook battery ? Will recheck area tomorrow for loose wires or vacuum leak. Wondered if anyone else had this problem. Zeke
Old 12-13-2012, 05:27 PM
2003 Olds Bravada
Yep cleaning the throttle body corrected the problem, was coated pretty good . Zeke
You may not post new threads
You may not post replies
