Which Bypass 04 TB Alarm/Remote start install? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 12-13-2012, 09:49 AM
Blitzedr6 Blitzedr6 is offline
2004 Chevy TrailBlazer LT
Black Granite Metallic 4.2L I6 4X4
I have a 2004 LT v6 4.2L Vortec 4200 Trailblazer.
My plan is to install an AutoPage C3-RS 730
I have found a couple threads on here regarding the install but I am confused as to which bypass to purchase for the stock key chimes, alarm, etc.
Here are some models I found, please suggest which would be the best for my application.
iDatalink ADS-DLSL GM1 Doorlock Interface & Transponder Bypass
http://www.ebay.com/itm/400264750554... 4.m1423.l2649
Xpresskit Xk06 Gm Remote Start Bypass Module GM Override Interface Xk-06
http://www.ebay.com/itm/380530695668... 4.m1423.l2649
Xpresskit GMDL-BP
http://www.ebay.com/itm/DEI-GMDLBP-C...em 2a26ec3df1
DEI 455G
http://www.ebay.com/itm/DIRECTED-DEI...em 53f0b09ab4
Xpresskit Optimax Series DLPKGM
http://www.amazon.com/Xpresskit-DLPK...dp/B001MWRXT6/
I found the above models in recomendations from threads on here. Not sure which one would be specific for y vehicle. I would like the easiest install possible.
Old 12-19-2012, 10:49 AM
After some further research on this forum i have decided that the xk01 is a feature rich bypass that can be had on ebay for less than $20. The alarm/starter that i went with is the autopage 730 which i also purchased on ebay for $126. Will post back when i get into the install. Any hints or comments regarding the install on a 2004 TB greatly appreciated.
Old 12-23-2012, 08:37 AM
djez015 djez015 is offline
2002 Chevy TrailBlazer LT
ads prob would of worked out easier
Old 12-23-2012, 12:23 PM
How so? Seems like the xk01 will do more than the others and you only need to wire the features you want to use.
Old 12-24-2012, 11:37 PM
I found that DEI modules lose there programming and lead to problems down the road ever since my shop switched to ads 4 years ago we have little to none re-works on remote starts installed
Old 12-25-2012, 12:46 AM
Thanks for the input. Would using the ads make the install any easier? It will for sure out last and perform than the xk01 according to what you guys are saying, correct?
Old 12-25-2012, 09:24 AM
yes and yes
Old 12-26-2012, 08:13 PM
This is the Xk01 unit I purchased
http://www.ebay.com/itm/380522027438... 4.m1439.l2649
It has ADSL firmware. I should still be able to complete the install with it without having to using an additional tool to program it correct?
I am debating on whether to by the abs unit and selling the xk01
Old 12-26-2012, 08:14 PM
I am debating on whether to by the abs unit and selling the xk01 but i would rather just use it to get it installed sooner if it will still accomplish what it states.
The ADS unit that I would want is the iDatalink ADS-GLSL GM1 for my 2004 Trailblazer LT
Old 01-03-2013, 12:07 PM
Would you still recommend the idatalink ADS-DLSL-GM1 over the INT-SL?
I sold the xk01 and will be buying a different bypass unit
You may not post new threads
You may not post replies
