remote start 08 envoy - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 12-20-2012, 08:24 AM
slredstorm62 slredstorm62 is offline
2008 GMC Envoy SLT
black 4.2L I6 4X4
Angry remote start 08 envoy
i recently installed a remote start in to a 2008 gmc envoy with the xk01 bypass. i only hooked up the remote start wires nothing for the lock/unlock and when i went to program the bypass all went fine until i started it. the vehicle started ran for about 5 seconds all the lights came on and it shut off. its a python responder one so its a good starter. does anyone have any idea why the security isnt working? i hooked one up in my 2003 envoy and had no issue. also hooked the xk01 into my 06 silverado and programmed fine
Old 12-21-2012, 08:24 AM
joey bonezz's Avatar
joey bonezz joey bonezz is offline
Medium Red Metallic 6.0L LS2 V8 AWD
remote start
it sounds like the bypass is not programmed rite or defective you may want to try a db all by xpressit or get a bypass were u have to put a key in the box that may help with the starting
Old 12-22-2012, 09:18 AM
2008 GMC Envoy SLT
black 4.2L I6 4X4
everything is hooked up the right way. i have used an xk01 and a dball bypass. both are programmed to the vehicle being amdl 6.0 for gm and the bypass modules both programmed fine. when it tries to start i have full voltage at the starter wire but it wont start. i am beginning to think this particular vehicle cant have a remote start put in it. i called gm and they dont make a gm remote start kit for it.
Old 12-22-2012, 01:05 PM
Loverotties Loverotties is offline
2002 Chevy TrailBlazer LTZ
I have a remote start in mine(Avital).
Old 12-23-2012, 08:29 AM
djez015 djez015 is offline
thats the problem your using DEI bypasses lol ,there nothing but headaches i been using I-data link ADS bypasses they never let me down and for these trucks they do every thing for you ......but if your stuck on using what you have I would try going over all connections and reset and reprogram
Old 12-26-2012, 01:15 PM
2008 GMC Envoy SLT
black 4.2L I6 4X4
I called gm and they said they dont make an accessory starter for that particukar vin number. Idk if i want to waste the money on a different type bypass if it will not work
You may not post new threads
You may not post replies
