Low Oil Pressure - Stop Engine - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 12-26-2012, 06:01 PM
mjouda mjouda is offline
2002 GMC Envoy SLT
Silver Mist Metallic 4.2L I6 4X4
Dear Tech and owners , hope you are fine !
i have 2002 Envoy 4WD,Today got a message ( Low Oil Pressure - Stop Engine ) ,
opened the hood , and heard a tapping /Knocking sound that come and go !
Oil Level is within range, no leak.
could it be the Oil pressure sensor ! or as i already hear the tapping it means that i have definitely other issues like ,
- Pump
- clogged Screen
how to figure it our !
it it possible to clean the screen without removing the pan ?
is it easy to change the pump !
Look forward to your nice inputs !
Best Regards
Old 12-27-2012, 10:47 AM
jason12 jason12 is offline
2003 GMC Envoy SLT
Dark Gray Metallic 4.2L I6 2WD
What does the gauge read?
Old 12-27-2012, 03:36 PM
2002 GMC Envoy SLT
hi jason , actually when this happened it was reading Zero , i stopped the engine and after a while started it again it went to normal but alternating to high when accelerating , i was planning travel but changed my plan , as i heard a knocking / tapping from upper side of the engine .
Old 12-27-2012, 04:17 PM
2003 GMC Envoy SLT
If the oil was changed regularly then the screen is likely clean and not an issue.
The only thing for DIY is to replace the pressure sensor. Other than this I am afraid it is the task for the professionals.
Old 12-27-2012, 04:44 PM
2002 GMC Envoy SLT
thanks for your reply , usually changing the oil on 2000 miles , was using Mobil 20W50 this is common in Saudi Arabia ,
i just changed the Oil and oil Filter,and used 10W40 on a hope that thinner oil may somehow help to open clogged screen , not sure it this makes a sense but trying anything before i go for opening the oil pan option which i guess not so easy with 4WD.
now trying to hear the tapping , but is no longer heard at least so far few hours after changing the oil and filter.
was unable to determine the exact location of the Oil pressure sensor , but found some sensors around the filter that the wires was full of oil perhaps due a possible to leaking in the area , cleaned them , blown them with compressed Air.
a free tech advice ! told me not worry about the oil pressure getting high while accelerating ,as their is a bypass valves that reliefs the oil pressure once it got higher than the max. allowable level . at least it indicates that the pump is not the issue .
And asked me to use the car and carefully monitor the gauge and sound for few days !
am about to travel 500 miles but will not trust the engine till i monitor it for .......
however will let you know ! Best Regards
Old 01-01-2013, 10:06 PM
blackblur blackblur is offline
2006 GMC Envoy Denali XL
Liquid Silver Metallic 5.3L V8 4X4
hey the same just happened to me about an hour ago and i'll be looking in to it in the next week as i dont need the SUV for the next while and my wife can use my truck and i have to fix my brother inlaws titan thing died on him 2 days ago and he needs it fixed before his wifes days off end blah blah blah oh yeah plus my day job :-l
Old 01-03-2013, 05:26 AM
2002 GMC Envoy SLT
Dear blackblur , looks you have a lot of fixes to do , in my case have changed the filter since then the gauge is on the middle about / normal , but noticed that it is increasing at higher RPMs . not sure of this is normal !
i came to know that recently fake duplicate filters is being sold to the oil and Tyre repair shops and i usually change oil at those shops not the dealer , so i have to consider buying filters from the dealer to avoid such case ,
my guess is that the Engine oil pump is a not easy to worn part so have to look into other issues before suspecting the pump or considering to change the pump ! Best regards.
Old 02-14-2013, 02:42 AM
bullguy's Avatar
bullguy bullguy is offline
2007 Chevy TrailBlazer LT
Imperial Blue Metallic 4.2L I6 2WD
Mjouda,i had this same problem a month back,now a days i don't see any message,by the way try to change your oil in Naft station petromin they are very prof people.
you will get all genuine parts there and once in a while try to do the engine flush,they do it there.
hope this will solve your problem
The roots of true achievment lie in the will to become the best you can become
Tags
low oil pressure
You may not post new threads
You may not post replies
