Power steering fluid leaking? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 12-26-2012, 09:25 PM
migkillertwo migkillertwo is offline
2002 Chevy TrailBlazer LT
Magnetic Red Metallic 4.2L I6 AWD
Hi all,
Today while i was driving the power steering started to fail. It was like one moment it was fine, the next it felt like turning the wheel with my car off.
It was on and off until I got to autozone and found that the power steering fluid level was low so I put some fluid with "stop leak" in it. I had never checked my power steering fluid level before. Right now the power steering works fine so it was caused by low fluid.
Does the trailblazer "lose" fluid every now and then, or could this only be caused by a leak? if so, how would I find a leak?
If it helps, I didn't see any puddles near the front, and I didn't smell anything that smelled like power steering.
Old 12-26-2012, 09:34 PM
Loverotties Loverotties is offline
2002 Chevy TrailBlazer LTZ
Look at the lines on passenger side that have the insulation over it(that's where they rust out most of the time).
Old 02-22-2013, 03:29 PM
sweet583 sweet583 is offline
2004 Chevy TrailBlazer LS
Emerald Jewel Metallic 4.2L I6 4X4
Power Steering Leak
I am also having issues with a power steering leak, I just recently had my racker pinion replaced last month, and noticed it leaking again, its a slow leak any suggestions
Old 02-22-2013, 03:56 PM
Where is the leak?if where the lines go in and out,could be the o rings,a bad line now or is at the boots?need more info.
Old 02-22-2013, 04:06 PM
Power Steering Leak
Old 02-22-2013, 04:10 PM
The leak is near the left tire, Im not to car or Truck Saavy
