[SOLVED] Tail Light Lens Removal - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 12-30-2012, 03:10 PM
Dirkpitt289 Dirkpitt289 is offline
2006 GMC Envoy Denali
Black 5.3L V8 4X4
I need to replace a couple tail light bulbs on my 2006 Envoy but am having trouble. I can obviously see the two screws after you open the rear deck lid but is there something else holding them in place? It seems to be stuck on the bottom and I don't want to break it by forcing it.
Old 12-30-2012, 04:02 PM
wcosh's Avatar
wcosh wcosh is offline
2003 Chevy TrailBlazer LT EXT
not sure if the Envoy is the same as the Trailblazer but those 2 screws are all that hold the lights on.
Go up to Resources and look up your owners manual. It will answer the question.
I'm sure the rubber seal around the light is just hanging up
Old 12-30-2012, 04:06 PM
Black 5.3L V8 4X4
ISSUE RESOLVED: For those that never replaced the bulbs on your 2002/ 2008 Envoy/ Trailblazer here are the steps.
Tools: All you need is a phillips screwdriver and a putty knife
First open the rear hatch to expose the screws. Next remove the screws using the phillips.
Next fit the putty knife between the lens cover and the truck body. If you are using a metal knife I would suggest covering the blade with tape to prevent scratching the body paint. I happened to have a plastic knife so I was good to go. Apply pressure rearward toward the lens. It should pop free of the body.
Use caution as the lens assembly can come loose very quickly and could drop.
FYI: This is the anchor points where the lens connects to the body
Using your thumb release the cable from the lens cover. The assembly is now free of the body.
Using the Phillips screwdriver I removed the electrical panel from the tail light assembly (3 Screws), exposing the bulbs.
Locate the burnt bulb and replace. I usually will replace all the bulbs at this point even the good ones. The bulbs come in pairs and cost only about $5 so why not?
The Envoy's and Trailblazers use a 3057 bulb
Assemble in reverse order of the dis-assembly. I hope this will help someone out there.
Regards
Dirk
Old 12-30-2012, 04:08 PM
Black 5.3L V8 4X4
Thanks Wcosh, I figured it out and posted a quick tutorial for future use.
