Fuel filter/code 1221 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 01-01-2013, 09:17 PM
stocktsi stocktsi is offline
2002 GMC Envoy SLT
Tis afternoon I replaced the fuel filter on my 2002 GMC Envoy. Also changed rear shocks and washed engine with water sprayer.
When I went to drive it, the Service Engine light and Reduced Engine Power lights were on, and the Envoy only crawls and does seem to want to shift out of 1st gear.
Checked code and it shows 1221. Reset the hoses to the new fuel filter to make sure everything in place and they look good. Tried resetting code and it comes back.
Tried disconnecting battery for about 10 min and same result after reconnected. Currently trying disconnect for an hour or so to make sure everything is cleared.
Any ideas what might gave happened? Was running fine before the maintenance work today. Could the fuel filter change have caused an issue? Or the engine wash?
Thanks in advance for your help.
Old 01-01-2013, 10:58 PM
2002 GMC Envoy SLT
One other piece of information: the traction control is turned off and I can't turn it back on. Originally had a traction control error code, but that has gone away since then.
Old 01-02-2013, 08:24 AM
Ray Dockrey's Avatar
Ray Dockrey Ray Dockrey is online now
2009 Chrysler PT Cruiser
Inferno Red Other 2WD
The key here is washed engine with water sprayer. I would say you either got water in a sensor or knocked the wiring loose. If you would have done a search on that code you would have realized that it has nothing to do with the fuel filter.
http://forums.trailvoy.com/showthread.php?t=70907
You may not post new threads
You may not post replies
