ABS/ Stabilitrak - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > Brakes
Brakes Performance Brake Upgrades
Old 02-15-2016, 02:51 PM
billibong145 billibong145 is offline
2006 GMC Envoy Denali
Red Jewel Tintcoat 5.3L V8 4X4
ABS/ Stabilitrak
Hello everyone. So I have searched through this forum and have found what could potentially be issues and solutions to my issue. But since none seem to list the same exact issues I have, I thought I would pose the question here. Recently I have had my ABS kick in at slow speed, 5 mph or less. No ABS or Brake light during this process. And right about the same time, my Stabilitrak has started kicking in when I start moving from a complete stop. Coincidence? Maybe. Related, not sure. Does Stabilitrak use the wheel sensors that the brakes use? I have seen yes and no. I have heard steering wheel position sensor and vehicle speed sensor as possible issues. I have read also abs sensors for the brakes obviously. I just want to know if they could be tied to the same issue or are separate. And has anyone experienced this and how did you fix? Thank you in advance.
Old 09-13-2017, 09:58 PM
johnnyo13 johnnyo13 is offline
2007 Buick Rainier
Black 5.3L V8 AWD
Hi did you ever figure out the problem? I'm having the same issues.
Old 09-21-2017, 07:40 PM
jimmer79 jimmer79 is offline
ABS etc.
I am also experiencing the same issues - anybody out there have any suggestions
Old 09-27-2017, 02:21 AM
2007 Buick Rainier
Black 5.3L V8 AWD
No still looking for a fix. Pulled fuse for ABS most of the problems have dissappeared. So I believe it's the controler
Old 09-27-2017, 11:02 AM
This behavior is usually caused by a weak front wheel speed sensor or rust/corrosion build up under the mounting plate for the speed sensor. Essentially, this causes a weaker speed signal being produced and the ABS gets confused.
Old 10-25-2017, 08:47 PM
Sneakycyber Sneakycyber is offline
I had this same issue (abs activation at slow speed) on a 1999 Chevrolet Blazer. Replacing the driver side front wheel sensor fixed the issue (passenger side was already replaced with the wheel bearing). There is a testing procedure in your service manual, and posted here on the forum.
Old 12-30-2017, 09:24 AM
ABS Traction control
Had front hubs/wheel bearings with new sensors replaced
Mechanic did not reset the in dash warning lights, how can I clear them?
